Old 10-06-2003, 06:45 PM
paris paris is offline
the difference between h22a jdm&usdm
i was told that the usdm h22a motor when dynoed made more hp than the jdm motor and it also cost less is this true
Old 10-06-2003, 10:49 PM
hondaracer hondaracer is offline
Re: the difference between h22a jdm&usdm
Cost less is true but I don't think there is really any significant power difference. Maybe like a couple hp in favor of the jdm motor if any.
Old 10-07-2003, 10:49 AM
Jdm_GUY Jdm_GUY is offline
Re: Re: the difference between h22a jdm&usdm
JDM engine features
a) higher compression ratio
b) slightly more aggressive cams
c) different fuel mapping
d) different valvetrain
e) tranny ratios are different
Bottom line stock usdm H22a will never outrun stock JDM H22a (if both in similar condition)
Let me know as i have a lot of JDM H22a engines and complete swaps.
Some have only 15-20k.
Old 10-15-2003, 08:18 PM
PolarBearWY PolarBearWY is offline
Re: Re: Re: the difference between h22a jdm&usdm
Originally Posted by Jdm_GUY
JDM engine features
I keep seeing people say that the JDM engines have different tranny ratios. How different? Does a USDM tranny not fit on a JDM engine?
Have a 95 Accord EX Manual with a rod coming apart and a tranny with slipping clutch (180,000 miles of hard driving -- got car to 146 mph) So, I need an engine... I need tranny work.
Been quoted $1800ish for JDM F22 installed with clutch work. Seems like it might be a little high, and may not be direction to be using a tranny with 180K on it. Seems like I can get 55 more HP for $1500 more, with the H22.
Please help.
Old 11-07-2003, 10:30 PM
crj_lll crj_lll is offline
Send a message via AIM to crj_lll Send a message via MSN to crj_lll
Re: Re: Re: Re: the difference between h22a jdm&usdm
USDM TRANNY / JDM Tranny
FD 4.27:1 / 4.266
1 3.31 / 3.307
2 1.95 / 1.950
3 1.36 / 1.360
4 1.07 / 1.034
5 0.87 / 0.787
RV 3.00 / 3.000
There are the gear ratio differences. The trannies bolt right up
Old 11-08-2003, 09:45 AM
93accordEX 93accordEX is offline
[quote=Jdm_GUY]
QUOTE]
because of a claimed 10 hp? its completely a drivers race they are so close in power. usdm tranny looks to me like its geared for better acceleration btw of course they are basically the same til 4th. and since when is the valve train different? anyways its not like Im arguing to say usdm is better cause its not, but I would just go with what you can find for cheaper/ better condition since they are basically the same(keep in mind perfect low mileage 30k JDM engines usually don't exist)
www.cb7tuner.com
Old 11-19-2003, 07:04 PM
Blitzfizz Blitzfizz is offline
Re: Re: Re: Re: Re: the difference between h22a jdm&usdm
hey there....i am curious about the gear ratios of the prelude....by seeing the ratios that you have posted, does it means that the jdm prelude has a faster acceleration but loses out at the high end? also, is there a relation between torque and speed in relation to the gear ratios?
thanks...
Blitzfizz
FD 4.27:1 / 4.266
1 3.31 / 3.307
2 1.95 / 1.950
3 1.36 / 1.360
4 1.07 / 1.034
5 0.87 / 0.787
RV 3.00 / 3.000
Old 11-19-2003, 07:15 PM
according to those numbers, that would mean the jdm would have a higher top speed, and theoretically a slower acceleration in 5th. but that really doesn't matter too much. what it means for what it will be used for is better gas mileage on the highway.
www.cb7tuner.com
Whats the difference between the different models? Jaxal General Discussion 0 02-10-2007 11:45 AM
how do i know the difference between a h22a and h22a type s lunatics209 JDM Motor & Parts info/chat 6 01-16-2007 04:30 PM
What are the difference between the SC VG33 motor and the VG33 NA motor? miloz31 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 01-02-2004 03:17 AM
the difference between h22a jdm&usdm paris Engineering/ Technical 0 10-06-2003 06:44 PM
What's the difference between the 4cyl engines in the Accord? rraven Engineering/ Technical 4 03-19-2003 09:59 PM
