Old 10-06-2003, 06:39 PM
upstatecivic upstatecivic is offline
16v cylinder heads
is there any difference between the 16 valve cylinder heads?
Old 10-06-2003, 07:02 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
which heads are you refering too? about 99% of honda heads are 16v.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-07-2003, 02:59 AM
91civicDXdude's Avatar
88-91 DX/LX/EX/Si heads are all the same with differnt cam for the d16a6 vs d15b2. the ports are identical, the valves are identical.
I have found a quick upgrade for any 16 valve non vtec honda.. a D16Y7 head from a 96-00 civic DX/LX. it is essentially the same head (16v non vtec), but with a differnt casting (plugs on the front like d16z6/d16y8) and the valves in the y7 head are the same size as the D16Z6 vtec head. why bother to buy larger "racing" valves when you can slap a y7 head on for hardly nothing, since they are often thrown away for a mini-me conversion
Old 10-07-2003, 07:04 AM
4thGen4Door's Avatar
4thGen4Door 4thGen4Door is offline
Re: 16v cylinder heads
so what do ya need? just the y7 head and new plugs? This will work on dpfi setup?
Old 10-07-2003, 07:09 AM
yep. it bolts right on. bigger valves, higher compression. cheap.
1994-302 aftermarket cylinder heads? spoovey F Series 0 05-21-2010 10:47 AM
Wanted I Need A Neon Sport DOHC Cylinder Head 1997-Dodge-Neon Cars/Parts for Sale/Exchange 1 08-25-2009 11:23 AM
