Old 10-06-2003, 05:09 PM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
car problems valves or something else
well guys my cars is messing up and im not sure whats wrong with it . i got a leak down test down my number2 cyclinder is low. the guy was trying to say that i need to just build my block i was like bs so now im hear my freind thinks its my valve would some bend valves cause my compression to drop in the cyclinder there bent in. the car is like missfireing and the check engine light is coming on. any help would be koo thanks
MODS: Motor :jdm b16 block, itr head, skunk 2 cam gears, msd ignition, intake, exhaust, straight pipe, skunk 2 ecu. act race clutch Suspension : grnd cntrl coilovers, 4 way adj shocks , spoon strut bar, skunk 2 sway bar, itr control arms, energy bushings misc. : super nice jdm seats, momo detachable steering wheel, Jdm clutster, Spoon Cf duckbill wing, vision smoked amber turn signals. COMING VERY SOON IN DAYS LS vtec ARP ROD BOLTS HEAD BOLTS AND 75 SHOT OF GIGLE JUICE look in my galler
Old 10-06-2003, 09:16 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yes with a bent valve you will lose compression, and cause mis fires as well.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-06-2003, 09:41 PM
ponchomuscle ponchomuscle is offline
if you or a friend can get to it. Pump air into the offending cylinder. Listen to the trottlebody, if you hear airflow there it's a bad intake valve. Go to the exaust pipe while pumping in the air and if you hear the air there it's prolly an exaust valve. Pop open the oil fill cap and if you hear airflow through the crankcase then your rings are bad and if you open the radiator cap and there is bubles you have a blown head gasket. This is the easiest way to check whats bad in the motor. If it be a valve the only work you have to do is head work. The block doesn't need to come out. Leave it where it is
Old 10-07-2003, 05:36 PM
Jeff C's Avatar
Jeff C Jeff C is offline
Re: car problems valves or something else
Did he not give you specifics? Did you pay for the leak down test?
-1989 Honda CRX Si, B18A Pic FOR SALE
-1998 Honda Accord EX Sedan 5spd
-1981 Chevrolet Silverado, shaved and bagged Pic
Old 10-07-2003, 11:05 PM
it was 75 dollars is it to much i dont remember me said that the 2 cyl. is only getting 10 percent compression
Old 10-08-2003, 03:10 AM
camaro67 camaro67 is offline
If a valve is bent or stuck open you would have no compression.
Can't compress air and fuel in a cylinder if both valves are not closed.
Old 10-08-2003, 02:45 PM
Buzz1167 Buzz1167 is offline
Send a message via AIM to Buzz1167 Send a message via MSN to Buzz1167
If the valve is completely jacked, then it cant have compression, but he doesnt know its broke (becuase it isnt). It wouldnt hold pressure at all, like camaro said. But if it was just a valve adjustment problem, then it could still hold some air, but let most of it out. He did say it was only 10% compressed right? Not 10% loss? Id just take off cover and check the valve lash with a feeler gague (just adjust the valves like you normally would on that cylinder (both sides)), unless your going to pay someone to do it, then I'd go through all the steps poncho mentioned before with the compressed air, before I'd pay money.
HTH
Buzz1167
Jon N
