Old 12-05-2001, 09:36 PM
VortechCivicSTL VortechCivicSTL is offline
Lightbulb HOW TO: Headlights on an Si ???
OI OI OI!! I'm lookin for a walkthru for replacing the headlight bulbs, BULBS, not entire units, properly on a 99-00 Si. I dont wanna fuck my water seal up again, so someone set me str8, I done fucked up. My lights are all foggy like my short term memory. :smoker2:
someone, tell me how its done properly. cuz im just the engine guy.
and damn, esthero is that summa summa, mmmmmm
<>\m/_,.:'*Fastc0de*':.,_\m/<>
"If you steppin' to me wif a weapon you'll be reppin' ya click in a box"
-www.kwur.wustl.edu-SAT 8-10pm
0o+ Only the Freshest Jungle +o0
Old 12-07-2001, 02:13 PM
Civic_Addict Civic_Addict is offline
How did you screw up you seal?
Old 12-14-2001, 05:36 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
1. Working at the back of the headlight, remove the rear protective cover. This will expose the connector fitted to the rear of the bulb. Carefully remove this.
2. You will now see the three terminals on the rear of the headlight bulb. The bulb is held in the headlight unit by a spring clip. Remove the clip and take out the bulb.
3. Replace the bulb, being careful not to touch the glass of the new bulb. They get very hot when lit, and the marks left by your fingers can cause them to blow.
4. Replace the spring clip and refit the rear protective cover.
hope that helps ya
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 12-16-2001, 07:15 PM
Question ahem
thanks for the walkthru for a PRE-2000 civic. but I run a 2000 Si, one cannot manuever your hand to unclip the housing without removing the battery, the front clip, and the entire untis themselves. what i am looking for is a walkthru of how to get to the damned lights. next time you see an Si, ask the owner to pop the hood and you will understand my perplexion.
yes
Old 12-17-2001, 02:31 AM
Re: ahem
yes
ok,well I'm sorry I couldn't find what you were lookin for, I only looked for 45 minutes and that was the best thing I could find.
2000 BMW 323IT
1954 Ford F100
Old 12-17-2001, 03:45 AM
xivera's Avatar
xivera xivera is offline
Wait a minute...
Is this the same layout as yours, VortechCivicSTL?
Isn't this the same on all SI's?
Anyway, to get to your headlights:
passenger side
Remove some parts of the airbox (not the battery) to access that one. (Perhaps, the top part shall suffice...)
driver's side
Pull up your power steering fluid-thingie and set aside (DO NOT REMOVE!!!) to access that one.
Good Luck!
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 03-08-2002, 03:54 AM
THE4TH's Avatar
THE4TH THE4TH is offline
Send a message via AIM to THE4TH
yeah man i don't know what your bitchin about
it's not hard to change a light bulb man...
even in an si, granted it's harder and a pain in the ass but it's still simple
on the drivers side just move the damn fluid container and squeeze your hand in there... and the passenger, just squeeze a hand in there no need to move anything not even the air box....
christ the hardest part is puttin the damn clips back in place...
just shove a hand in there and poke around till ya get it man
S2000
Old 05-27-2004, 09:21 PM
twopointzero twopointzero is offline
::sigh::
dude, 1996 to 2000 honda civics are virtually identical. something as simple as changing a headlight bulb should be self explanatory, provided you have the common sense it takes to actually be a mechanic. anyway, at the most, ona 2000 si you might have to r&r the power steering revisor, if you have fat arms and hands. then unplug the harness from the lamp. slide off the rubber boot. unclip the headlamp and remove. reverse for installation.
