Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 10-05-2003, 05:57 PM
Maximln Maximln is offline
Power Window problem
I have a 96 Dodge Avenger ES and I am having a problem with the power windows. Both of them stopped working. I guess it could be the motors but it seems odd that both of them would quit at the same time. There is a 30amp power window fuse under the hood that seems to be good. I've exchanged it with other 30amp fuses in the panel and they all seem to work properly. I've also taken the switches apart and they seem to fine as well. I've removed the door panels and all wiring seems to be OK. Does anyone have any other suggestions other than the motors? Is there some sort of relay or other fuse that could be the problem? It seems like there is just no power to the motors.
Thanks in advance,
Max
Old 12-08-2003, 08:12 PM
HotFlames786 HotFlames786 is offline
Send a message via AIM to HotFlames786
I'm not too sure about that. I have the same year and model as you and haven't had any problems. Sounds like you checked everything that I can think of too...I'll let you know if I come up with any solutions!
Old 12-13-2003, 09:22 PM
Thanks so much for your reply. I really don't know what else to check.
Thanks again,
Max
Old 12-22-2003, 08:35 PM
jay6g73 jay6g73 is offline
get a voltmeter and check for power when u hit the switches
Old 12-16-2009, 11:41 AM
zbars1977 zbars1977 is offline
Re: Power Window problem
try checking the power window relay, i believe its in the fuse pannel inside the car, at the top above the fuses....im having same problem, let me know if you find the solution, gonna check mine tomarrow.
