Old 10-05-2003, 05:32 PM
cee cee is offline
sub/amp question
I wanted to purchase 2 subs and an amp and was just wondering if there was anything wrong with my choices, and if it would sound good. The subs are 2 10" kenwood tornadoes and the amp is JBL 600.1 bp mono amp. Here are the specifications:
Kenwood 10" 600-Watt Subwoofer
Dual Voice Coil No
Impedance (Ohms) 4
Peak Power Handling (watts) 500
Frequency Response (Hz) 28Hz - 800Hz
Sensitivity (dB) 91
Woofer Cone Material Pearl Mica Injection-Molded Polypropylene
Woofer Surround Material Urethane
Voice Coil Design 2-Layer, Vented Voice Coil
Basket Material Steel
xMax - Maximum Excursion (millimeters) 12.0
QTS .83
Fs - Free Air Resonance (Hz) 35
Recommended Amp Wattage Range 18 - 300 Watts Recommended Enclosure Type Small Sealed or Ported
Amplifier Type: Mono
RMS Power: 300W x 1 @ 4 ohms
Bridged RMS Power: 600W x 1 @ 2 ohms
THD at Rated RMS Power: 0.1%
Speaker Level Inputs: Yes
Preamp Outputs: No
Built-In Crossovers: LP
Bass Boost: 0-6 dB
Frequency Response: 10-320 Hz
Channel Separation: n/a
Signal to Noise Ratio: >100 dB
Fuse Rating: 2 x 30 amps
I don't really know much about car audio, so any feedback will help me tremendously. Thanks
Old 10-05-2003, 11:46 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
Nice choice on the amp, I dont know about the subs though. I would look into a pair of Adire Audio Shivas (www.adireaudio.com) they are a 12" sub, but way worth the extra $$$ (I have the JBL 600.1 runnin 2 of the Shivas myself, and I couldnt be happier). Or if you want 10" subs, I would look into the JL 10w3 or even the Alpine Type R, IMO
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 10-06-2003, 01:46 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: sub/amp question
those tornadoes aren't bad for wetting your feet with, but you'll see that there are much better subs out there
Empty Pockets Racing Member #1
