Old 10-05-2003, 03:42 PM
AstroRide44's Avatar
AstroRide44 AstroRide44 is offline
How to stop orange peel
Hey, i just got a Revel Lightning(which sucks, nothing fits very well) but i tried P-mans painting with out primer trick and when i sprayed the car i got hundreds or little blobs of paint. anyone know the best way to get rid of it, but more importantly how to stop it from happening. thanks max
Old 10-05-2003, 04:20 PM
Kasso's Avatar
Kasso Kasso is offline
Send a message via AIM to Kasso Send a message via MSN to Kasso Send a message via Yahoo to Kasso
Re: How to stop orange peel
where is this "no-primer" trick??
1995 Acura Integra Special Edition (something real special about a 5000 rpm changeover... )
Old 10-05-2003, 08:39 PM
hobbes874's Avatar
hobbes874 hobbes874 is offline
Send a message via AIM to hobbes874
Without primer I don't think I could ever get a good finnish.
All Newbies please read the F.A.Q's
"We are defined by the choices we make." -Fight Club
Old 10-06-2003, 11:52 AM
iceblend's Avatar
iceblend iceblend is offline
perhap u can try sanding the car surface with grit 600 before u spray the paint...
Work In Progress
Old 10-06-2003, 11:58 AM
freakray freakray is offline
AF Modelrater
What kind of paint are you using? How are you spraying it? If you're using an airbrush are you thinning the paint?
Are you thinning the paint enough? How far from the model are you spraying? Where did you find P-man's 'no primer trick'? Did you read the FAQ? Did you look through the 'How to and Tutorial thread?
Did you wash the body before you started spraying.
There are so many causes to why paint goes wrong and anything from preparation of the surface to paint type can be a factor.
AF User Guidelines
Old 10-06-2003, 03:58 PM
levelgrape levelgrape is offline
Send a message via MSN to levelgrape Send a message via Yahoo to levelgrape
I also bought the Lightning kit and am doing a body drop and lowering job on it but so far I have not sen any errors in fit it just takes the normal sanding and cutting to align everything I have heard about people running into an issue with the bed and tailgate before but nothing a hobby knife and sanding can't fix.
Old 10-06-2003, 04:02 PM
drumcat's Avatar
drumcat drumcat is offline
ice done many models without using primer and i got great fantastic results you just have to sand the spraypaint out and the give the body a little good sanding or use some primer
