| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Distributor Cap
I just bought a D16Y8.....and the distributor cap seems to be a little dirty...(screaming for a change)
I was wondering how hard it is to change it? |
Re: Distributor Cap
Re: Re: Distributor Cap
Remove the old distributor cap(3 bolts 8mmor 10mm) w/ plug wires attached
Install new cap & tighten gently, its plastic & will crack if over-tightened. switch plug wires over to the new cap in the same spots. I agree with Hondaracer, basic tune-up stuff he listed is very simple with the right tools. Like he said it would be wise to replace the rotor while the cap is off. Its only a few bucks. Make sure the screw has thread lock on it, honda rotor comes with screw & thread lock applied. To replace the rotor: Dizzy cap off You may need to turn the engine to get at the screw Remove screw then rotor Reverse for install - you cant mess it up. You could, but it would be pretty hard to. [img] |
