Go Back   Automotive Forums Car Chat > Mazda > General Discussion
Old 10-05-2003, 07:51 AM
92pro 92pro is offline
i still can't get help on why my mazda won't start...
ok i bought a mazda that will sometimes start and run great, but 99% of the the time it just cranks.. I checked all the obvious and it wasn't getting spark etc, so i tested all the ignition stuff. Thats when I noticed that the check engine light doesn't come on when i flip the key to the "run" position. IF and very rarely IF the check engine light does come on then the car starts with no problem... Now I checked grounds to the computer, even tried replacing the computer... I know it gets 12 volts from at least one wire going in... anbody happen to know if thats enough?? ITs a 92 protege with the sohc and 5-speed if that matters.... please help save a mazda from destruction as i have a temper > lol
Old 10-07-2003, 10:18 AM
Sexy beast's Avatar
Sexy beast Sexy beast is offline
Banned
Take it to the mechanic, they have all the gizmos to do electronic checks. You are capable of screwing up the electronics yourself by poking around.
Old 11-18-2003, 09:24 AM
MazdaB1300 MazdaB1300 is offline
Send a message via AIM to MazdaB1300
Re: i still can't get help on why my mazda won't start...
Although it's not very likely, it could be in the connection in your ignition switch. The starter circuit could be good but the rest may have a bad connection of some sort. That's just a suggestion
93 B2200 w/ a 13B rotary
Old 02-14-2006, 02:56 PM
my13waysused my13waysused is offline
Unhappy Re: i still can't get help on why my mazda won't start...
I seem to be having the same problem with my 1993 Mx-3. I have never had a major problem with this car and it has 176xxx on the odometer. One day i pulled in the driveway, and tried to start it about 10 minutes later, and it cranks but refuses to start. I also noticed the check engine light will not display when the key is turned to start. I thought the computer wasn't getting power, so I checked grounds and wires and found nothing. I replaced the distributor 2 times -with used but good ones, rotor, spark plugs, plug wires, coil, ignition module and I still have the same problem...it refuses to start up and is getting no spark
I know it isn't the fuel pump...ive checked that...what could it possibly be??
Old 02-27-2006, 08:45 PM
rjitzsu rjitzsu is offline
no spark on an early protege = distributor
9 times out of 10
Old 06-09-2007, 02:46 PM
lchapman lchapman is offline
i have a 1993 mazda b2600i and sometimes it will start and sometimes it won`t. I have changed the distributor a couple years ago and the wireing harness from behind the switch down the stearing colum an a used ignitor just last week and it still wont` start every time. Any help would be appreciated.
Old 06-15-2007, 10:47 AM
Somebody1 Somebody1 is offline
Someone had the same problem here, I think there was a thread about the fix.http://www.coremazda.com
Old 10-12-2007, 01:37 PM
bigeric bigeric is offline
My mazda ran out of gas about a year ago and has been siting. Now it wont start. P.S. I did put gat in it. What to do???
