Old 10-04-2003, 11:07 PM
HONDABOND HONDABOND is offline
Water pump gasket?
Hey greg was saying he got a gasket for his water pump... When I got my ZC it didnt have one, it was just honda bonded on... So thats what I did, I honda bonded the fucker back on... I have to take off my lower timing cover to fetch some nuts that fell in there and I was wondering if its realy nessisary.
White folk eat noodles too.
Old 10-05-2003, 01:19 AM
BullShifter's Avatar
Re: Water pump gasket?
It wouldn't be there in the first place if it wasnt necessary. Honda Bond is good stuff but I wouldn't trust it for sealing the water pump, a small leak over time will cause the t/belt to get weak & eventually break. A broke timing belt is always a good thing, what does the gasket/o-ring cost? couple bucks?
Old 10-05-2003, 01:35 AM
GTA's Avatar
GTA GTA is offline
Whee..
Re: Re: Water pump gasket?
are you sure about that im pretty sure a broke timing belt is always a bad thing in hondas. i dunno when i said i got a gasket for mine though, only time i was talking about one was the one on my moms old wagon 307
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-05-2003, 01:42 AM
Re: Re: Re: Water pump gasket?
You get more power with a broken timing belt
Old 10-05-2003, 04:52 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
the water pump rubber o rinis only 2 bucks
Get those bolts out of there!!!! my friend dropped a bolt down his timing belt, the belt picked it up, slung it through the gears ripped a hole in the belt and fucked up one of his cam gears and shot a hole in the valve cover!
Old 10-05-2003, 05:02 PM
Did your friend know the bolts were in there?
If he did, your friend is a MORON!
I know a guy who dropped a wing nut down inside the carb. & thought it would be OK to start - Sucked that nut right in the engine & caused all types of damage fuckin' people
Old 10-05-2003, 05:05 PM
H4Bangin's Avatar
Nope, didnt know
i have known people that didnt know somethin fell into the carb too, found out what it was after tearing apart the engine and finding a bolt or a nut on top of a fucked up piston
watch your nuts
and bolts
