Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-04-2003, 02:51 PM
grncivicdhr's Avatar
grncivicdhr grncivicdhr is offline
AF Premium User
Send a message via AIM to grncivicdhr
Question lsd conversion...?
i wanted you guys to check this... out....http://cgi.ebay.com/ebaymotors/ws/eB...tem=2435707168
i've heard alittle about it on the civic forum last year, but what do you guys think about it. i'm sure theres a difference. its a lot cheaper that a real clutch lsd, but around the same price as the vlsd from a 300zx. what would you do? do you think the vlsd is better?
ohhh, by the way, what was nissans product code for the vlsd in the 300zx, r???
and also, how does this product work? i'm just curious.
Old 10-04-2003, 06:03 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Re: lsd conversion...?
I think it's pretty good for the most part. It's definately a lot cheaper than a kaaz or cusco unit. If your considering buying this or a 300sx VLSD, then go with the phantom grip because the 300ZX diff will end up costing you more because of the new output shafts your going to have to buy.
The diff's code is R200.
When the plates on the phantom grip are under spring tension, it causes them to twist in opposite directions and wedge outward on the spider gears. That will cause friction between the spider gears and the diff case which will then cause the wheels to turn at the same speed.
The only thing I don't like about to phantom grip is that when the plates are twisting, they are putting pressure on the spider gears which could cause them to break. I haven't heard of this happening yet, but I wouldn't be surprised if it did. Many people I know use it and absolutely love it for the price they paid.
Old 10-04-2003, 08:13 PM
AF Premium User
thanks for the info, i'll be looking into getting it and i 'll tell you guys what i think.
LSD in d16z6 transmission sohcd16beast JDM Motor & Parts info/chat 0 07-31-2010 03:10 PM
1967 Mustang Gas to Electric Conversion 1967mustang Performance 4 11-12-2009 10:23 PM
1995-200? Lumina (GM) radio LED conversion saxonmor Car Audio 0 03-01-2009 09:59 PM
95 240sx 5 lug & LSD conversions 240orso 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 04-30-2006 10:54 PM
YS1 LSD Conversion? crv-tec Let's get Technical! 3 03-07-2005 11:57 PM
