Old 10-04-2003, 02:36 PM
tc3 tc3 is offline
1991 fuse question
can somene tell me what the fuse for the lighter, reading lights and the convertable release button thing for the camaro.., and while im asking, what could be the problem with the car if the rpm guage isnt working and the speedo doesnt work much anymore, could those be fuses as well...??
o and one last thing, the drl(daytime runing lights?) fuse is not there is that bad and could it be messing anything up
thanks much for anything...
Old 10-06-2003, 12:13 PM
top_down_camaro's Avatar
top_down_camaro top_down_camaro is offline
I'm having the same problem with my 91.
I checked all fusses but cannot find reading lights and top release button.
Neither is working. Lighter, try replacing the lighter itself with an aftermarket. Thats what i did for mine was bad.
Old 10-07-2003, 01:22 AM
Doug000 Doug000 is offline
Send a message via AIM to Doug000 Send a message via MSN to Doug000 Send a message via Yahoo to Doug000
Re: 1991 fuse question
I cannot help you with the fuse problem, but check the wire harness connection going into the back of the instrument cluster AND the ECU.
Old 10-07-2003, 09:19 AM
tc3 tc3 is offline
well i figured out the fuse for the top release, lighter, lights and everything else was the acc(accessory) fuse in the box, pulled it out and the middle was burnt and broken, so replaced it and it works great now, but dont replace it with the rear hazards fuse, i did that thinking it was the park hazards for when you have to pull onto the side of the road but i guess it does all the brake lights and that stuff...
