Cruise Control help needed
I have a 2002 Buick LeSabre and just recently the cruise control stopped working. The control is on the steering wheel. If I push the ON/OFF switch, the Cruise light comes on and the cruise control works. However, now I have to HOLD the ON/OFF switch to keep the cruise working, it will not stay on by itself. When I let go of the ON/OFF switch, the cruise light goes off and the cruise control shuts off. Any suggestions on how to fix this??
Re: Cruise Control help needed
turn it on, and press the set button on the stalk.
[Read your owners manual]
tman.. thank you for responding to my cry for help.
I can't turn the cruise on. I push the ON/OFF switch, and it's on.. but it's only on until I let go of the ON/OFF switch. While I am holding the ON/OFF switch down, I can use the SET switch.. but that only will work if I continue to hold the ON/OFF switch. Once I let go of the ON/OFF switch, the cruise control shuts off. It appears that the SET switch is working fine, but the problem is with the ON/OFF switch. I hope the way I am explaining it makes sense to you. |
I understand what your saying, the on off switch is a toggle switch of 3 functions. on/off/(resume/accel) apparently, that lilltle switch has broken. I'd imagine you'd have to replace the whole turn signal stalk. Flatrater may be able to help.
Re: Re: Cruise Control help needed
Thank you again, tman, for responding. How would I contact Flatrater? I am a bit new to Automotive Forum.
Re: Re: Re: Cruise Control help needed
You need a new switch!! The one mounted in the steering wheel. Its easy to replace you just need a little screwdriver pry on the side of the switch it pops out unplug the switch and replace it.
Shop Foreman Buick Pontiac and GMC dealership ASE Master Tech ASE Advanced L1 GM Master tech Licensed Aviation mechanic |
Re: Re: Re: Re: Cruise Control help needed
Flatrater.. thank you also for responding.
My husband has a question. If he were to pry off the switch as you suggest, will it set off the air bag? He'd rather not be surprised. (grinning here.. should tell him "no" if the answer is "yes" ?? JUST KIDDING!!!!) Thank you again for your advice.. and your patience. |
Re: Re: Re: Re: Re: Cruise Control help needed
If you keep the key out of the ignition there is no way for the air bag to blow! The air bag needs power to blow. And you shouldn't even come close to the bag itself.
Flatrater,
It was the switch!! Total cost to have the cruise working again... $ 18.51 Thank you so much for your help! Thank you both.. tman and flatrater.. for responding! |
for flatrater; could dealer replacement of body module affect hedlight switch?
