Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 10-04-2003, 08:41 AM
IntegraBoy2003's Avatar
IntegraBoy2003 IntegraBoy2003 is offline
question about camber...
I just bought civic and the kid has a 3 inch drop with body kit, it looks sick but cant even get it into a shop, he has coilovers, i was wondering if i need camber kits if I decide to make it 1.8 or 2.0 inch, please somebody let me know!!
http://www.retardsoftheday.cjb.net <<MY SITE, check it out, it is quite funny and Updated Every day
New York Yankees Join the asses, that rock the masses
David
Old 10-04-2003, 01:08 PM
akina_speedstars akina_speedstars is offline
Re: question about camber...
First, please write your posts with some clarity.
I would recommend that you install a camber adjustment kit on your car as it is in order to get a lot of negative camber. Negative camber will slant the wheel so that the top of the wheel in inward, kind of like that exaggerated cartoon drawing of a WRX at the top left hand side of this webpage, so it won't rub against the car. Positive camber is when the top of the wheel is outward; drivers who do autocross do this and want to make sure the tire contact patch is large when the car is going through turns. Most cars have a small degree of negative camber.
Old 10-05-2003, 01:14 AM
hondaracer hondaracer is offline
Re: Re: question about camber...
But beware that too much negative camber will make you lose traction. Just get a good camber kit and you should be fine.
