Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 10-04-2003, 08:55 AM
ddowen1 ddowen1 is offline
Question 97 E320 -looking for tips on removing passenger door panel
Can anyone provides tips for removal of the front passenger door panel without damaging parts?
Old 10-09-2003, 03:46 PM
Mark Cummins Mark Cummins is offline
W210 door panels
The W210 door panels are very easy to remove!
Remove the SRS plug and the round cap under the door pull
remove the Plastic cover behind the inner door release ..remove the phillips screws and remove the door panel
If You Need Pics here is the Mercedes site on all tech Issues
http://www.startekinfo.com/StarTek/
Old 10-14-2003, 09:39 PM
blindside.AMG's Avatar
blindside.AMG blindside.AMG is offline
Send a message via AIM to blindside.AMG
A wedge is a very helpfull tool to have after you remove the screws because the clips that hold the panel on can be pretty damn tight. Just slide the wedge between the door and the panel at the bottom and pop out the clips. There should be about 6-8 clips around the parameter of the panel. You might also want to buy some extra clips because sometimes they tend to break.
