Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-03-2003, 07:15 PM
rdean85 rdean85 is offline
Question motor oil in radiator
i have a 1987 dodge ram 50 and motor oil is getting in the radiator but water is not getting in the oil . what could be going on????????????????
Old 10-05-2003, 06:31 AM
frankendart frankendart is offline
Send a message via AIM to frankendart Send a message via Yahoo to frankendart
Hmmm. Not sure about what's happening there.
What engine do you have? Is it the 2.2L or 2.5L?
Is the truck a manual trans, or an auto? (if auto, are you sure it's not trans fluid in the radiator? which indicates a radiator problem.) There would also be a indications of antifreeze in the trans dip stick.
Do you have an oil pressure reading? (Should be aound 60-90 lbs. for a 2.2L, and and 35-65 lbs. for a 2.5L @ 2K rpm).
Does the engine smoke? If yes, what color?
If you don't have an auto trans, and you are NOT seeing cross contamination (oil in radiator AND antifreeze in crank case), I'd ALMOST rule out any kind of block or head crack (?). I would tend to lean toward a gasketing problem.
Check your compression, look for two cylinders next to each other that are low. (2.2 130-150 lbs., 2.5 100 lbs).
Thanks,
Frank
SUCK-SQUEEZE-BANG-BLOW!!!!
It's just how things work!
I own 4 Fords, 3 Chevies, 3 Saturns, 2 GMC's, and 2 Dodges... So tell me about your brand loyalty.
Old 10-23-2003, 07:38 PM
Re: motor oil in radiator
it is 4 speed yes on the oil pressure reading, no it does not smoke
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
