Old 10-03-2003, 12:04 PM
NANOO NANOO is offline
Question Which other cars has this Engine??
What year and kind of car has a 1.8 DOHC that will bolt into a 91 Honda Civic Si after a few mods?
Thanks
Old 10-03-2003, 12:15 PM
civicHatch civicHatch is offline
Send a message via AIM to civicHatch
the 1.8 DOHC engine comes out of a 1990-2000 integra. 90-91 is B18A and has 130hp but comes with cable tranny. 92-93 is B18B with 140hp and comes also with cable tranny. when u get to 94-95 it is no longer non-obd wireing like 90-93. 94-95 is obd-I and 96-2000 is obd-II.
All of these engies are B series so u would need a new set of engine mounts to accomadate your D series engine bay. The easiest swap would be the b18a, less wireing.
AC
-88 dx with 89 JDM integra XSI engine tranny(Limited Slip Differential) ecu, Iceman intake, hiflow cat, apexi n1 muffler with 2 1/4 " piping,
Old 10-03-2003, 12:27 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
actually all 90-93 Are B18A's, its just the 90-91 is OBD0 and the 92-93 is OBDI. the 94-01 However is the B18B1. If you are wanting to swap one in, i would recommend the 90-91 OBD0 B18A, that way you wont have to deal with any wiring.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 10-03-2003, 12:28 PM
Ok so the years 90-93 Integra are the best to go with?? There is no other cars with this engine?? Would it be much more difficult to go with the B18B?? What else would I need besides mounts and linkages??
Thanks
Old 10-03-2003, 12:34 PM
90CRXZCSi's Avatar
yea 90-93 will work, but i think 90-91 will work better since its OBD0. The B18B would be ok, but you will have to wire it from OBDI to OBD0 or from OBD2 to OBDI, but then you would have to get the whole car wired for OBDI, if you went with an OBD2 motor. You would also have to get a cable tranny, since all B18B's come with hydrolic. You will just need the mounts and a new shift linkage otherwise. If you have any more ?'s, just ask.
-Bryan
Old 10-03-2003, 12:51 PM
Ok so stick with 90-91 and than I just need the mounts and a new shift linkage nothing more?? Do you know of any cheep places to get mounts and linkages?
Thanks
Old 10-03-2003, 12:53 PM
90CRXZCSi's Avatar
www.hasport.com has the mounts. You might have to make your own custom shift linkage or look on www.ebay.com for all that stuff.
Old 10-03-2003, 12:59 PM
Ok thanks for the help guys!! Any idea what a 91 Civic Si 1.6 SOHC engine an 5spd tranny worth with 171,000Km on it?
Thanks
Old 10-03-2003, 01:19 PM
91civicDXdude's Avatar
my advice.. get a 90-91 B18A1, swap a newer head on it, and you have more power. the 90-91's had shafty cams and a crappy flowing head.
Old 10-03-2003, 04:11 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Which other cars has this Engine??
won't he need the teg axles too?
Empty Pockets Racing Member #1
Old 10-03-2003, 04:22 PM
What are teg axles??
Old 10-03-2003, 08:26 PM
GScivic7's Avatar
teg = short hand for integra
Old 10-03-2003, 08:57 PM
Well I'm getting the whole car so I can use them too. They will fit right?? Thanks for pointing that out though!!
Old 10-04-2003, 08:59 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
they will fit once you take the dust caps off of your front knuckles. if you leave them on, you prolly will still be able to make the CV shafts fit, but you might get binding and you dont wanna kill the wheel bearings.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 10-04-2003, 01:06 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
Re: Re: Which other cars has this Engine??
screw it....get a b-20 2.0 liters of tourquie goodness
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
