| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
dual throttles
my friend has a 98 civic ex dohc vtec and we wanted to 'add' another throttle to it. now how would i go along doing this? we're gonna put some kind of divider in the intake manifold so one throttle goes to 2 cylinders and the other throttle to the other 2 cylinders. of course the fuel injection will be upgraded and a custom intake manifold. i've seen something like this done before on a ford focus, and i was wondering how i would go through this process of creating it?
Re: dual throttles
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable. |
Re: dual throttles
Might as well go for four itb's.
Re: Re: dual throttles
Re: Re: Re: dual throttles
Individual Throttle Bodies.
i've thought of that, making 2 smaller intake manifolds and putting a throttle on each. but what else would i need to do to make it work?
If you think the throttle body is a restriction in the intake (and it probably isn't) why not just get/build a bigger one?
Re: dual throttles
the biggest throttle out there is someting like 80mm, *correct me if i'm wrong*, 2 air intakes each going to a throttle body-has nothing to do w/ resriction, it's just getting more air in there.
Actually, 2 TB's will ease up the restriction (if thats where the air is being restricted) because less air will have to flow through each TB in order to provide the same amount of air as through a single throttle body. But chances are, it wont really matter for a stock motor (by stock i mean more than a K&N and a high flow axle-back system).
Beer tastes better upside down. Last edited by Sluttypatton on 13-54-2098 at 25:75 PM. |
Re: dual throttles
<has nothing to do w/ resriction, it's just getting more air in there.> How would you get more air than you need? Either you don't have enough air because of a restriction in the intake, or you have enough (excluding cases with really bad intake tuning).
Your absolutely right, if your engine is already getting enough air, making the intake system less restrictive doesn't really matter.
ok, yea you're right, the engine is getting enough air, the normal amount a stock vtec would take in. but what i'm looking for is more air. it's like the forced induction thing-more air mixed w/ the right ratio of fuel will create more power and THAT'S what i'm looking for, more power. having an intake and a throttle will give me a set amount of air. by adding another throttle, air intake will double-theoretically. all the while, the car is technically naturally aspirated.
Re: dual throttles
It doesn't work like that. If the engine is getting all the air it can process then any more air you give it won't do anything. What the dual throttle body system could do, if designed properly, is maybe give better throttle response. Think about it, if this thing worked it would have been done already.
ah alright, icic. well thanx for your explanations.
