Old 10-02-2003, 08:37 PM
NANOO NANOO is offline
Question Engine swap question
Ok I am new at this, I got a full car lined up to buy. Its a 91 Acura Integra RS, Can I just take that whole setup and drop it right into my 91 honda civic SI or is ther more things I need to buy first. Its a 1.8L DOHC.
Thanks for your time
Dale
Old 10-02-2003, 09:06 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Re: Engine swap question
You need engine mounts and shift linkage but other than that its a direct bolt in.
Old 10-02-2003, 09:12 PM
SiZ's Avatar
SiZ SiZ is offline
www.hasport.com
That site should help answer some questions, they sell the mounts nessicary for the swap.
"The nympho of info, I'm fuckin' what ya heard"
Old 10-02-2003, 09:13 PM
Thanks for the reply!! Ok so where do I get engine mounts and a shift linkage??
Thanks Again
Old 10-02-2003, 09:17 PM
SiZ's Avatar
SiZ SiZ is offline
The site that I sent you a link for.
Old 10-02-2003, 09:25 PM
Yea sorry I saw that after I reposted!! What about the wiring, does it all plug in to the si wiring? Why cant I use the linkage system out of the Acura, or is that totally different??
Thanks
Old 10-02-2003, 10:00 PM
The Integra engine is a B-series and your stock one is D-series. The B-series takes a shorter linkage, but you cannot use an Integra one because it won't bolt up to your car.
Old 10-02-2003, 10:09 PM
Ok so what about the wiring?? Questions, Questions, Questions.
Thanks
Old 10-02-2003, 10:51 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
it should all be plug and play with the wiring
KoRnSaQ
Old 10-02-2003, 11:18 PM
Posey88cvic4dr's Avatar
Posey88cvic4dr Posey88cvic4dr is offline
Send a message via AIM to Posey88cvic4dr
Whats kinda specs is this engine putting out?
4g4d4Life <--Link To My Car
TEAM CHOZEN
Old 10-02-2003, 11:26 PM
Ok so just like FourthGenHatch said, that's all I need is engine mounts and shift linkage, Correct?? I assume I have to replace the Si computer with the Acura's?
Anyone know the cheapest price I can get engine mounts and shift linkage?
What Is a 91 Civic SI engine worth with 171,000 KM?
Thanks
Old 10-03-2003, 01:51 AM
91civicDXdude's Avatar
you can modify the integra's shift linkage by cutting a couple of inches out of the shift linkage and stabilizer rod. do a couple test fits before you cut, and make sure you weld them together well. I did this, it worked totally fine.
