Old 10-02-2003, 03:52 PM
unforgiven unforgiven is offline
Question 350
will a 350ci engine fit(wiring and all) in my 94 z28? it currently has a v6. and up to what size will an engine fit in my car?
thanks,
Alec
Old 10-02-2003, 08:36 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
Well, for one, if you have a Z28, then you should already have a V8 LT1 that's a 350. If it is a V6, then it's not a Z28.
Secondly, if you do have a 94 V6, then an LT1 shouldn't have a problem bolting in there. It's technically a 346, but that's neither here nor there...
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 10-03-2003, 02:11 AM
Misundaztood's Avatar
Misundaztood Misundaztood is offline
Re: 350
I read the lt1 was a 350ci & the ls1 was a 346ci though I read that on some import forum so it was probably wrong.
Alan
Old 10-03-2003, 10:38 AM
They're both 5.7L motors, which equal 346 cubic inches...
Old 10-06-2003, 01:00 PM
thanks for the reply. one more question, does it have to be an lt1 in order to fit in the camaro, or can I just buy a 350 small block chevy(i want more horsepower than what lt1 has to offer) and install it without having to do any serious rearranging? thanks again
Old 10-06-2003, 05:32 PM
Well, the V8's that bolt right into a 94 Z are going to be LT1-derived powerhouses. An LT1 383 would be one that started as an LT1 350 and was bored over to get 383 cubes. I think that's how it works...
Old 10-07-2003, 12:19 AM
Doug000 Doug000 is offline
Send a message via AIM to Doug000 Send a message via MSN to Doug000 Send a message via Yahoo to Doug000
Re: 350
When comparing a stock pre-LT1 350 vs a LT1 350, the LT1 has more horsepower (and reliablity). But if you are wanting to modify either enige, the LT1 will cost you more on some of the parts (intake, heads, fuel system).
Old 10-09-2003, 07:12 PM
i dont think u understood my question. i meant to ask if a non-LT engine would bolt up to it. like a 350 smallblock or something. and what's so good about the lt1 engine? its only like 275-305hp no?
Old 10-09-2003, 07:18 PM
Re: Re: 350
i've seen some LT1s on ebay going for pretty low prices(below $1000), Lt1 has more horsepower than any other 350? i saw a 350 with 557hp crate engine for $3500... then again im a newbie so i dont know much about this stuff but feel free to tell me about it.. or just flame me : ))
Old 07-02-2004, 05:13 PM
blkthunder blkthunder is offline
The difference in a 350 LT1 and a reg. 350 is the LT1 comes factory stock w/ 275-305 hp but it will last longer because it has a 4340 steel crank and special lite weight pistons. If you rubuild an LT1 and put just any piston they will be too heavy and to big. Yes a reg 350 will bolt up to your car( same block bolt pattern). Also A 383 is bored over but it has a 400 cubic inch crank in a 350 block. the crank length is the same as the 350 but the stroke is different. It produces alot of low end tourqe as well as top end power. good luck
Old 07-02-2004, 05:35 PM
boosted331 boosted331 is offline
Re: 350
No, they are NOT both 5.7L motors. The LS1 is 3.90" bore and 3.622" stroke, which equals out to 346.14 cubic inches, or 5.672 litres. The LT1 uses a 4" bore and 3.48" stroke, working out to 349.85 cubic inches, or 5.733 litres. 5.7 litres rounds out to 348 cubic inches, not 346. Neither motor is truely 5.7 litres, it's rounding on both parts.
Old 07-02-2004, 07:54 PM
Dober89 Dober89 is offline
Re: 350
If you look at the sales sticker on an LS1 camaro or trans am, does it not say "5.7L V8"???? Ive never heard it advertised as a 5.6L. Besides if you round off what amount it is in litres, it gets rounded upto 5.7L. They are both 5.7L engines, just different blocks and the displacement is a little off.
As far as fitting an older 350 into your 94, they should all fit no problem. You may need different motor mounts but I dont see any reason why you couldnt stuff one in there because they arent really any different in overall size.
Old 07-03-2004, 01:25 AM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
Re: 350
liters cant be acuratly comparted to CI really. proving my point, how is a 302, 305, and a 307 all 5.0 liters. it is all just rounded.
and just asking to maybe give unforgiven something else to think about, but, will he have to swap his trany out too or is the bell housing the same patern?
<<my engine
<<part of the front end during engine swap
other pictures of my car... click here
Old 07-03-2004, 01:28 AM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Re: 350
Ok, he is right, a 350 smallblock is 350ci in dispacement, an Lt1 is 350 inches in displacement, but an LS1 in 346 in displacement, as yes, it is a totally different engine so the bore and stroke are completely different. And a 383 is a Stroked 350 not bored.
Old 07-03-2004, 07:23 AM
Re: 350
383 is bored AND stroked 350 :P
to 350 or not to 350 ndoerr Pick-Up 3 05-31-2006 09:36 PM
Pontiac 350 and turbo 350 tranny toenailclippers S-10 3 04-18-2005 07:52 PM
Differences between diesel 350 and gas 350 pro_am Engineering/ Technical 8 07-14-2004 05:07 PM
95 350 upgrade to vortec 350, anyone done it? RS72SS C/K 3 01-27-2004 07:33 PM
