Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 10-02-2003, 01:04 PM
g_funk3 g_funk3 is offline
Rough Idle for my 1990 300zx
I havent taken it to a mechanic yet, but I was curious if anyone else ever came accross this, or had any ideas? The car has about 70,000 miles, and runs really good at higher rpms but at idle it is rough, and taking off feels like it is missing til the rpms come up or the turbo comes on.
Thanks for any info
Old 10-03-2003, 07:02 AM
aimeensc aimeensc is offline
i'm having a similar problem with mine...
I've put some fuel injector cleaner in my gas and it seems to have helped some so far
my car's an 86' with 190,000 miles on it so i'm sure i'll need two bottles of the stuff
Old 10-05-2003, 02:59 AM
300zxtc 300zxtc is offline
Re: Rough Idle for my 1990 300zx
Thanks for any info
i own a 91 300zx tt has 101000ks and has a diffrent motor in it and yes it sounds exactly like my car as well it'll have a big flat then then the turbos hit in and then it can nearly send me sideways i love it but it's annoying every now and then as well it will idle very round from 500-1500 does it on and off every now and then and usually i think it's when it needs a service tell me what would u prefer a 300zx or a gtr 32 skyline they don't look nearly as good but they sure go i dunno weather to stick to mine and slowly do it up costing me heaps or just go bang for bucks and get gtr r32 "?
Old 11-09-2003, 09:16 PM
CP Restorations CP Restorations is offline
Rough Idle
I have a 90 300z that had the same problem. I had a mechanic work with me to find out the problem. We changed plugs, ran injector thru it, and tested just about everything. What we found with mine was this, the oil pressure guage would drop to 0-10 psi when it was at idle, that is when it would run bad. I change the ooil pressure switch and it cured it. So if your oil pressure is low then you may wnat to change the switch. I bought mine from Nissan direct about $60. If you need a part number let me know. Good luck
Old 11-27-2003, 06:59 PM
rizzspeed's Avatar
rizzspeed rizzspeed is offline
Send a message via AIM to rizzspeed
Check the throttle position sensors. The connections might be corroded and not making good contact sending the ECU the wrong readings.
You might also want to check over your vacuum lines for a possible vacuum leak.
96 Cutlass Supreme w/ Rough Idle, but drives good chrisluna Cutlass Series 1 09-17-2009 07:29 AM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 09:34 AM
Rough Idle Mayathebee Cougar 1 03-22-2009 08:23 PM
Looking for 1990+ 300ZX TT Sandhawk Classifieds 3 06-23-2004 07:27 PM
Remote unlock for 1990 300zx craigerd2 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 3 10-14-2002 01:55 PM
