Old 10-02-2003, 08:41 AM
4g4d_getone's Avatar
4g4d_getone 4g4d_getone is offline
91 si instrument cluster
my boy has a donor car cause he crashed it (a 91 crx si) he gave me his instrument cluster, and his seats.
my question is will the 91 cluster fit in place where my 88 cluster is?
if u dont know its the rpm,speedometer....etc..
Y LOOK FAST WHEN YOUR NOT?????????
Old 10-02-2003, 08:50 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
not directly, you will need to mod some things to get it to work.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-02-2003, 09:00 AM
so if i get the 88-89 version will that bolt up
Old 10-02-2003, 09:08 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Re: 91 si instrument cluster
yes it will
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 10-02-2003, 10:49 AM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Even if the '91 cluster did bolt up, the tach, idiot lights, etc.. wouldn't work. You can't use a '90-91 cluster in a '88-89 - and vice versa.
Old 10-02-2003, 02:02 PM
BlueCrxNC's Avatar
BlueCrxNC BlueCrxNC is offline
Send a message via AIM to BlueCrxNC Send a message via MSN to BlueCrxNC Send a message via Yahoo to BlueCrxNC
It is true that swapping cluster gauges between 88-89 & 90-91 is not a perfect situation but it can be done. The shape of 88/89 cluster top is flat while 90-91 is tall and round and of course the cover would need to be swapped as well. The hardest part is rewiring the connectors... I don't know which ones must be moved but there are many I'm sure.
It can be done but it requires more than just a screw driver
Old 10-02-2003, 03:36 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
i'll trade you my 88-89 for your 90-91 i need one bad, i hate my huge ass autozone crap tach, but i ahve a 88 cluster, and i dont want to rewire anything that important
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 10-02-2003, 04:12 PM
4thGen4Door's Avatar
4thGen4Door 4thGen4Door is offline
can't you swap out the 88-89 dash for the 90-91 dash? Then it should bolt up. This is a link for the re-wireing http://www.4thgenerationcivic.com/how-to's/aftermarket-Custom.htm
It's at the bottom.
Old 10-02-2003, 04:28 PM
aight then im just gonna find some junk yard down here that has a 88 lx cluster
Old 10-03-2003, 12:17 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
You can wire in the 91 cluster, check out www.4thgenerationcivic.com I wrote a how-to on there and its actually quite simple once you think about it. But it is adviseable to go ahead and keep with the same yrs, looks alot better, because if i'm correct you can't swap out the cluster bezels.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-03-2003, 09:17 AM
you CAN swap the bezels out between 88-89 tto 90-91
Old 10-03-2003, 06:38 PM
Re: Re: 91 si instrument cluster
So if you swap the bezels and mounting brackets and do the re-wireing then you can swap the years? The dash is the same?
Old 10-03-2003, 11:09 PM
Re: Re: Re: 91 si instrument cluster
correct, i had a 90-91 bezel on my old primered hatch....it didnt fit the cluster because the cluster was that of 88-89 origin, but the bezel hugged the dash. the only difference is that the hazard switch and the instrument dimmer knob are actually on the bezel, so if you get a 90 bezel for your 89 make damned sure you get the dimmer knob and hazard switch because if you dont ahve the hazard knob ur signals wont work, and if you dont have a dimmer swithc, your guage lights wont work.
