Old 10-02-2003, 04:46 AM
elvinKee elvinKee is offline
Send a message via ICQ to elvinKee
help~~~
i just doin my 350z,after done all the painting,
on the left side door got somthin like scar??got few very small white hole on that scar!! don't know what's
that??it came out when i was doing clear coating!!what should
i do now?redo all the painting??hav any solution that no need to redo
all the painting???
Old 10-02-2003, 04:56 AM
Focus2000's Avatar
Focus2000 Focus2000 is offline
Evil Genius
If it only appeared when you were clearoating, it may just be a problem with the clear. You could try very carefully wetsanding/polishing the affected area until the mark disappears, but don't go too far and ruin the paintwork underneath.
Chris
Old 10-02-2003, 10:22 AM
Re: help~~~
i already sanding that area,i think i need to add a coat of paint on that area!can i jus paint a light coat only on that area??by the way,i already done all the panel lines and window frame!will the colour turn very big different???plz teach me how!thnks!!
Old 10-02-2003, 10:56 AM
hirofkd's Avatar
hirofkd hirofkd is offline
You can mask everything else but the door panel, and apply the same amount of paint and clear coat to the door to fix the problem.
What's the body color? If it's metallic, pearl or mica, it's very hard to match, but it's worth a try. If it doesn't work, you'll probably have to strip the entire paint.
Hiroaki Fukuda
Old 10-02-2003, 12:03 PM
Re: help~~~
another question,izzit sanding all over the door panel?
Old 10-02-2003, 12:36 PM
hirofkd's Avatar
Re: Re: help~~~
Yes, mask the body along the panel lines, fiill the scratch if necessary, sand, prime and paint the body color and clear coat Then, remove the masking tape. If the color is solid opaque color, such as black, white, blue, it should work, but translucent colors like red, yellow and metallic are hard to match.
Hiroaki Fukuda
Old 10-02-2003, 01:01 PM
bobby28384's Avatar
bobby28384 bobby28384 is offline
Grammar lessons would help us trying to help you too! Thanks!
Volkswagen. Drivers Wanted. Don't be a ricer. Get a Golf.
