Old 10-02-2003, 01:07 AM
furiouspontiac68 furiouspontiac68 is offline
Send a message via AIM to furiouspontiac68
Question 6 speed transmission
Like How Much Would A 6 Speed Transmission Cost ??????????
Old 10-02-2003, 12:38 PM
FAPhoenix's Avatar
FAPhoenix FAPhoenix is offline
Send a message via MSN to FAPhoenix
Well I'm going to take a guess here and throw out that you want to make a 1968 Firebird perform right with a 2002 Trans Am with an LS1 and 6-speed right?
Anyway I think you can order a new T56 for around $2000.
You might need an adapter plate depending on the tranny year and engine type.
There are a few considerations though:
1) How much time are you planning on spending above 140mph?
oif so are you sure you want to take a 1968 Firebird to that speed because even at 135mph my car is scary at those speeds.
2) If you keep the Pontiac engine there is a lot more torque then other engines (LS1 etc.) because of their design. So they are more like a viper with endless torque and less need to always be in the right gear.
3) If you plan to do track racing you'll probably only need a 5 speed anyway.
4) 1/4 Racing you only should be using the first 4 gears anyway, use the 5th as OD to drive home with your 4.56 gears.
A 5-speed is cheaper too.
Back to the point, your 6 speed you'll probably want is a Tremec T56, and and adapter plate. Not to mention a lot of work to install it under your car, especially if your car is an auto like mine. (Crazy amount of work to install a standard).
Old 10-02-2003, 08:41 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
You can find an entire LS1 and tranny for $4500 if you look hard enough...
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
