Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 10-01-2003, 11:14 PM
Lastkiss8988 Lastkiss8988 is offline
Question Experience needed with my suspension
i have a 90 hb and am looking for advice with my suspension. im looking to lower the car 2inches and inhance with some aggressive handling...any suggestions/ideas or anything
Old 10-01-2003, 11:22 PM
BullShifter's Avatar
Re: Experience needed with my suspension
There are many quality choices.
Whats your budget & do you wants adjustable ride height?
Old 10-01-2003, 11:45 PM
Re: Re: Experience needed with my suspension
If its not an Si, most likely it does not have a rear sway bar. Adding a rear sway bar with a good suspension set-up will help handling greatly. I have 2 rear lower control arms(rear sway mount) & a stock rear sway for your car if you want to buy it. I would suggest purchasing a larger than stock bar, Suspension Techniques does not require the hole in rear control arms for mounting so you can use your stock LCA's.
Old 10-02-2003, 01:40 PM
Budget isnt not much of an issue. adjustable ride height in struts would be nice,and lowering springs would be nice to go with it along with a front and back strut bar and what system should i get for each and etc...car is not an si what would it cost all on its own and how much would it cost to get it done?
Old 10-03-2003, 12:00 AM
Re: Re: Re: Experience needed with my suspension
As far as strut/tie bars go, Neuspedd makes some nice solid bars. Other tie bars on the market dont really do any thing because they have hinged ends. Strut/tie bars & sway bars are easy to install & can be done yourself with basic hand tools. Personally I would upgrade the sways before adding upper strut bars, rear sway mainly! I didn't like the way my car handled with a larger front sway, so I run a stock front sway with poly bushings/endlinks & a larger rear bar(ST). Rear sway & lower tie should be used together.
You adjust ride height with adjustable coils, not adjustable shocks - Koni's have adjustable spring perches - lowers 20mm(front) -- 15mm(rear)
Eibach - H&R - Neuspeed for springs
Koni - KYB - Tokico - Bilstein for shocks
H&R - Tein for true coilovers
www.tirerack.com
www.summitsportcompact.com
www.jcwsportcompact.com
when upgrading shocks/struts also upgrade the upper strut mount bushings
I cant think what the labor hrs are off-hand, thinking 2.5-3.0hrs not including alignment.
My suspension on the 91 civic si :
Eibach Pro-Kit
KYB AGX's
Neuspeed tie bar(all 3)
Custom made front lower tie
Suspension Techniques rear adjsutable sway
Stock front sway - poly bushings
Energy Suspension bushing kit(about 50% installed)
I am very happy with the ride/performance. If I had to do it over again I would have gone with H&R coilovers. I can now get stuff from Tire Rack for slightly higher than cost and that includes H&R products
Get yourself a repair manual from www.helminc.com -- you may want to do it yourself then.
