| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
N2O... high or low compression?
I figure logically since N2O just shoves more oxygen in your engine at a denser rate (nitrogen makes the oxygen molecules freezing cold so it condenses) and that N2O itself does not raise compressoin(like a turbo or supercharger) that having High compression (to a certain extent 10.5-11:1) and N2O would be safe for a street car, and in comparison something like running 4-5psi on a turbo with an intercooler that has about a 400% effiecency rate. Does this make any sense?... even if my turbo analogy is a way off... can someone please just answer the question... would semi-higher compression in the 10.5-11:1 range and a small shot (35-65) of N2O be safe? (assuming the block has been resleeved with new rods and pistons)? BTW i have a 92 prelude Si, H23
Two things.
1. Nitrous oxide systems do not shove more oxygen into your engine. It's more of a symantic error than a technical error. Your engine breathes in the same amount of air whether you are adding nitrous or not. It's just that when you inject nitrous oxide, there is more oxygen present to burn more fuel as opposed to the air that comes from the outside. Turbos and superchargers shove more air into your engine. 2. Nitrous is safe (safe as in it won't blow up your engine if you drive properly and have properly installed a quality nitrous system) with either high or low compression engines. |
Re: N2O... high or low compression?
[quote=MXrider22]I figure logically since N2O just shoves more oxygen in your engine at a denser rate.
Thanx for the help, but i never said anything about taking in more air lol. Just Oxygen, and maybe cramming it in there was a bad way of saying it as the air goig into your engine is more oxygen dense with N2O. But you answered my question so with a safe wet 55shot on 11:1 compression its street so im going to be running 93octane.... i would be safe and not break anything (with moderate usage not runnin it all the fricken time) |
"I figure logically since N2O just shoves more oxygen in your engine at a denser rate."
Re: Re: N2O... high or low compression?
If you want to do a high-compression nitrous setup best way to go, imo, is to run as high of compression as you can on your highest octane (if you get 93/94 octane i'd go with 12:1, if you get 91 i'd stay to 11:1-11.5:1) pump fuel, then run a small fuel cell in the trunk filled with race gas and run the nitrous sytem off that. That way if you're out cruising you still have good N/A power, but if someone wants to race you can run em straight up with a bigger (>100HP) shot of juice without needing to totally fuel up on some race gas.
So what your saying is...
So what your saying is run 2 seperate tanks... the stock tank AND a small cell in the trunk... and when i want to run the bottle.. wtich over the race fuel... Question though, if i could run the 11:1 off 93 ocatne in the first place... why would i have to up the octane to run N20??? and if i did...if i didnt use the race fuel in the cell would it go bad after a month or so... and how could i do that just switch back n forth at say a stoplight or something
Re: So what your saying is...
ok
So your saying run a wet kit which will inject the nitrous and the RACE fuel not the 93octane... but wouldnt that meen that id be running nitrous C16 and pump gas all at the same time.. What kind of effect would that have... mixing C16 with 93 octane and throwing N2O on that fire??? Has anyone ever done this that i can talk to
Re: ok
thats awesome
So i could run 11.5:1 comp (being safe dont wanna go to 12 or 12.5) with built internals like pistons, rods, i wanna run cam and then get a decked out head job, i could run say a 75wetshot (NX) but run the C16fuel with the NX setup? if so sounds like a nice 250-300hp setup, not to mention i could roast alot of the crap around here (damn civics) lol
Re: thats awesome
nice
That could be fun, the motor making around 200-220 on its own, then run a 150shot... i wouldnt get beet by too many people thats for sure, i could only activate it once i already passed like 60-70 cuz id break loose in 1st 2nd or 3rd gear. But it sounds like an awesome setup, ive got some $ saving to do... But 1 more question... The stock H23 Sleeves... i know its a closed deck block, but how much can those things handle?.. cuz a golden eagle resleeving would make for some killer insurance, but im not so sure about 1000$ in insurance
