Old 10-01-2003, 09:57 PM
kopo0001 kopo0001 is offline
97 Blazer
I have a 97 Blazer with a 4.3L Vortec V6.
It has been starting very hard, idling rough when cold and hot, and hesitating when trying to accelerate. I pulled a code out of the computer that said 'Random Engine Misfire'. A few people have told me it may be the fuel pressure regulator. Is there an easy way to test this part, and also how difficult is the replacement/have any tips or hints?
Thanks
Old 10-02-2003, 11:35 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
It may be that the injector poppets are stopped up.
The poppets cannot be cleaned by conventional means (injector cleaner and additives).
GM has a special procedure and tool to unstick and clean the poppets.
I have done many of these unstick procedures with great sucess.
You can test the fuel pressure regulator by installing a fuel pressure gage and watch for fuel pressure drop when the engine is turned off.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-10-2003, 12:54 AM
Mr Clean Mr Clean is offline
This excerpt is from my brother who warned me about this problem before I bought my Blazer.
"4.3 vortec engines with CIS injection are prone to a peculiar problem. Most commonly the complaint will begin with the vehicle running poorly followed by excessive fuel consumption and the smell of an acutely rich exhaust. The problem is a leaking fuel pressure regulator inside the upper intake plenum.You can verify the priblem by attaching a fuel pressure gauge to the valve at the rear of the intake on the driver's side and checking for pressure loss with the engine off. When you key on pressure will go between 60-70 pounds, after a minute or so it should maintain at least 50 psi. Unfortunately the regulator is part of the injector assembly and is quite expensive. Also don't count on your local shop to figure it out until after they have sold you a tune-up, MAP sensor, MAF sensr, fuel pump, oxygen sensor and any number of other parts. I used to go to other shops after they pulled their hair out they would call me and then they were really pissed when it takes five minutes to identify the problem. This one used to throw a lot of people off, way off."
Hope this helps dude.
