Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-01-2003, 08:31 PM
MikeX MikeX is offline
Door switch panel
How do I remove the switch panel from the driver's door armrest on a 1996 Camry?
Old 01-28-2004, 02:48 PM
rnfloyd rnfloyd is offline
Re: Door switch panel
Hi Mike,
I don't know if you still need this info, but here's a link with step by step removal of door panel (actually for replacing speaker) on a Camry. Pick the step that you need. Even has pictures. It's fairly simple.
http://www.carstereohelp.com/stereor...CamryFSpkR.htm
Hope this helps.
Old 01-28-2004, 07:28 PM
Thanks very much. That's mostly good info, except for removing the switch panel. If you pry it up as shown, you break the tab off. There is a screw at the front end of the panel that should be removed first, after the panel is removed.
Old 01-29-2004, 09:22 PM
Joe W Joe W is offline
Have you gotten it off yet?Are the switches faulty?
Old 01-29-2004, 09:29 PM
The switch tests good, so it must be a broken wire or a loose connection, probably behind the door panel, which I haven't taken off. Getting the door panel off is such a big job that I haven't done it yet. When leaving the car, we can lock all the doors by leaning over and pushing the passenger door lock button, or we can use the key after getting out.
Old 01-30-2004, 08:33 AM
Re: Re: Door switch panel
Originally Posted by MikeX
<snip> Getting the door panel off is such a big job that I haven't done it yet.
It's really not that bad Mike. Just follow the instruction in that link above. You can leave the switches still attached to the door panel if that's a problem since there is enough wire to the switches to move the panel around... (at least on a 94 Camry there's enough wire).
Hope this helps.
96 door panel mikeburrit01 1st Gen 95-99 3 04-24-2010 03:26 PM
removing quarter panels and doors Douglas91 Cavalier Problem Diagnosis 0 02-13-2010 03:51 PM
04 yukon xl driver door instrument panel problems kminton85 Yukon 0 01-09-2010 10:57 PM
Where is located the sliding door AJAR switch? serge_saati Windstar 2 10-06-2009 06:31 PM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
