Old 09-30-2003, 06:31 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Engine detonating
My car is detonating, I am running high compression but on low grade gas (87 octane). I am forced to run cheap gas because I cant afford the 91 octane gas. I set my AEM cam gear to TDC and retarded my timing on the dizzy. I don't want to mess with my timing anymore, can I adjust my fuel pressure? My thinking is that more fuel will prevent pre-ignition since too much air and not enough fuel will cause detonation. Do you think if I can raise my fuel pressure, it will level out the air/fuel ratio and get rid of the pinging?
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 09-30-2003, 07:31 PM
HONDABOND HONDABOND is offline
First of all what compression are you runing? Secondly you have to run 91+ if you are over 11.0:1 and generaly you cant go past 12.0:1 on 91... Unless you can tune like a mofo...
Also, who made your pistons?
White folk eat noodles too.
Old 09-30-2003, 08:08 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Re: Engine detonating
Not trying to be funny, but you can put money into your car, but you can't afford an extra .20 in gas??
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 09-30-2003, 09:14 PM
You know T-mo I was wondering the same thing... I meen, if i cant afford 91+ octain gas for my car... I dont drive it.
Old 09-30-2003, 10:07 PM
91civicDXdude's Avatar
the b16a2/3 engines are only 10.2:1 compression (USDM) and they require only premium unleaded or better gasoline..
Old 10-01-2003, 04:15 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
maybe before you guys all bag on him for not being able to afford higher octane gas you should check his location ... arizona ... home of the $3.79 gas prices a few months back ... and im willing to bet its still pretty high.
secondly if you drive as much as i do, an extra 20 cents per gallon adds up. Then again im not running high compression because with this weak dpfi, and stock zc internals it wouldnt do anything for me anyway.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 10-01-2003, 05:13 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i know you were repling to seth but.....get your b series junk outta here redcivicracer drives a red shoe powered by d16 bay-be
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
