Old 09-30-2003, 11:13 AM
mommyrcr mommyrcr is offline
Send a message via AIM to mommyrcr
Unhappy I need HELP, please?!?!
I hope this is the right place.. .I have 96 GSR motor in my car and when I start it up, it just stays at red line and just keep s bogging there unil we turn it off. We don't know what could be causing this... Is the motor shot in someway or did we miss something? I would really rather avoid getting another motor, much less another swap. So if anyone out there could help me with this or has come across this problem before after a swap, we would appreciate it! Thanks in advance!
Old 09-30-2003, 01:49 PM
Buzz1167 Buzz1167 is offline
Send a message via AIM to Buzz1167 Send a message via MSN to Buzz1167
Stays at red line? Like rev's up to 7000rpm by itself or something? If check the throttle cable to make sure its not stuck. Also Id check the connection on the manifold, take off the air intake, and look down the barrell, there should be a circular flap that is mostly closing (like 95%)the hole at idle, if it is gone, bent or just in the wrong postion, you need to fix it so it works like this (closed at idle and open at full throttle). There is a throttle adjustment screw on the intake maifold too, so that might be way to high or something, it should be at the top left of the throttle body.
HTH
Buzz1167
Jon N
Old 09-30-2003, 04:57 PM
thanks. i'll check that out and hopefully it works...
Old 09-30-2003, 06:40 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
try unplugging the IAC. that should drop the idle. If it doesnt then something is messed up with the wiring.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-30-2003, 08:37 PM
Could it be that the intake manifold gasket was not properly installed? I took the manifold off and found that the pieces of the old gasket were still stuck there. Could it be that it wasn't a good seal?
