Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 09-30-2003, 11:50 AM
Alexjohn Alexjohn is offline
Thumbs down Timing Belt replacement
Hi!
I have Mercury Mystique 98, 4 cyl (2.0L) equipped with Zetec engine.
I bought it half a year ago with mileage of 111 kmiles. Previous timing belt was not to bad but needed to be replaced soon.
I have replaced timing belt recently. After that before putting the covers on I found out that the belt have a tendency to slip off the camshaft sprockets. In spite of this I closed the covers and drove only 60 miles or so. Then my engine stopped because the belt weakened and the exhaust camshaft turned about half a turn but the belt did not slip off completely. When I unbolted the covers I found out that half of it width was damaged and almost cut off. I installed new timing belt, tensioner and both idler pulleys. When I check it again and the belt was slipping in the same manner as first time even I gad set the correct tension and torque. I have decided then put a piece of flat metal foil between the tensioner and the engine body (half of the area of the tensioner washer in direction out of the engine) glued it with epoxy. The foil thickness was 0.2 mm. After that I have tested the engine again before installing the covers. The belt was OK. To be precise it was moving slightly out off the engine at high acceleration (5000 rpm) and towards the engine a little at idling speed. But it was stable and did not come to the edges of the sprockets. I think the reason there was either hole of the tensioner which is not perpendicular to the engine for the or slightly bent camshafts. I am really in doubts about the last because it is not easy to bend the camshafts. The car ran about 100 miles and checked the belt. It was OK. Now I am keep testing this stuff.
Here is my experience. Did anybody have such a bad experience with the Zetec engine? Did you have any problems during the warranty period?
Thanks
Alex
Old 09-30-2003, 12:43 PM
Sam I am Sam I am is offline
How do you bend a camshaft? Did you do any hammering to the engine? Maybe the original owner was a bit rough on it.
Old 09-30-2003, 02:22 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Timing Belt replacement
Ouch Green hurts! Moved to the correct forum.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
