Old 09-30-2003, 08:30 AM
83_Camaro-350 83_Camaro-350 is offline
Send a message via ICQ to 83_Camaro-350 Send a message via AIM to 83_Camaro-350
Motor is screwd up and I Don't know whats wrong HELP!
About two weeks ago I was driving my car and it missed a couple of times then quit. ABout 3 days later it did it again but a little worse , then again quit. ABout 2 days latter yet again and wrose yet. Till yesterday, i was comming up this hill and it wouldnt quit missing and back firing. The bad thing is , is that the car is in time. What is wrong????
Old 10-01-2003, 04:56 PM
Musclecarclub's Avatar
Musclecarclub Musclecarclub is offline
Re: Motor is screwd up and I Don't know whats wrong HELP!
Could be a number of things. Bad gas, a carb problem, or a faulty spark plug. Better take it to a mechanic.
1971 Buick GS Convertible
350-4bbl w/ 3-speed Auto
1 of 599 made
Modifications: None - Totally stock!
Former owner of:
1969 Buick GS 400 Convertible
Modifications: 430 4bbl. V8 (from a '68 Riviera), Stage 1 spec Carb, headers, 2 1/2" exhaust, transmission shift kit, and column tachometer - to name a few ...
Old 10-25-2003, 03:14 PM
dk 55belair dk 55belair is offline
I would check the distributor cap and change it, might have a crack also rotor cap while youre there
Old 11-09-2003, 08:52 PM
Llogoaero Llogoaero is offline
It sounds like a problem with the distributor itself. You most likely have an HEI and they have a problem with the "pole piece".It's a small electrical part underneath the rotor,The small wires are prone to breakdown.You might want to check this out as well as any excess free play in the shaft .
Old 11-30-2003, 05:56 PM
TEXAS-HOTROD TEXAS-HOTROD is offline
Sounds like a bad plug wire to me. When they start to break down, it's more prone to miss under a load (going up hill). I have seen spark jump from a weak distributor terminal to a strong one.
Change the cap/rotor/wires and see what the plugs look like.
---TEX---
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
