Old 09-29-2003, 04:52 PM
bellesboss bellesboss is offline
Question 1999 Tahoe Electrical Problems
HELP! My '99 Tahoe is draining its battery. There is a noticable clicking sound when the engine is off, and the doors are open without the keys in. THe battery is dead, and it takes a jump to get it started again. Our mechanic says he checked everything and can't find anything wrong, other than something is draining the battery. Any ideas?
Thanks
Old 09-29-2003, 06:42 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Try and find out where the clicking sound is coming from...that might be the source of your drain.
You can also remove the fuses one by one until the noise stops and then go from there.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-30-2003, 02:48 PM
According to the mechanic, all systems check out ok. I was told the clicking sound was being made by some component that is looking for a power supply and the the newer GM products will do this. Unfortunatley, they can't seem to find the power drain.
Old 10-07-2003, 03:06 PM
rludlam19 rludlam19 is offline
I have the exact same problem. I just bought the car so I took it back to the dealer I got it at. I will post a reply if they fix it and let you know what it is. Just curious--When this started happening on mine the inside lights would just come on while I am driving down the road. And the transmission started slipping from 1st to 2nd. Is any of this happening on yours also?
I have 1 1999 Tahoe LT 4wd
Old 01-02-2004, 11:01 AM
fkellehe fkellehe is offline
Re: 1999 Tahoe Electrical Problems
I have a 2003 that has similiar problems, without the clicking. The battery has drained 5 times in 3 months, anytime it is cold teh problem happens. It has ben to the dealer 3 times the first time they replaced the battery and checked all the charging systems without a problem. If the vehicle is not driven in a 24 to 36 hour period it will be dead. It is going in again today I will post the results when I get it back. I also ran into a person at the dealer with the same problem. A short exist somewhere and it seems to be a problem that has existed for a period of time.
Old 02-04-2004, 02:32 PM
2tonemg 2tonemg is offline
Similar prob w/ my 99 LTD -- battery dead overnight. I discovered that dome light comes back on several minutes after I lock the door and it fades out. I'm in the house before I noticed it come back on. Any ideas?
Old 02-04-2004, 05:08 PM
Re: Re: 1999 Tahoe Electrical Problems
My 2003 ended up being a wiring harness under the power seat that ended up coming apart and caused the wire to fray when the seats moved bak and forth. The short would pulse every 25 to 30 seconds. The dealer went and taped all the harnesses under each seat. The problem is solved.
Old 02-14-2004, 11:42 AM
captofdt1 captofdt1 is offline
Had the exact same problem with my 99 tahoe, dead battery, interior lights not going off or coming on after truck had sat for a while. Replaced battery, problem went away for only a month!! Everything electrical checked out; Alt, bat, starter all OK. Started over, ended up being a slightly loose ground cable from battery, where it attaches to the engine block. All the gremlins went away. Hope this helps.
Old 02-18-2004, 12:53 AM
Blazin56 Blazin56 is offline
Had a probelm with my 99 also.The interior light would not go out, had to push override button,so no interior lights at all. Ended up being the driverside door switch. Over time the spring wears out. Got part around $6. Replaced and no prob. since. Good luck!
Electrical Problems...... GaryCifers Corsica 6 01-13-2010 04:08 AM
Need Help with 1999 Tahoe Electrical Issues! derekw7 Tahoe 9 11-30-2007 12:08 AM
1999 Tahoe Electrical Problem, Won't Start kodiak41226 Tahoe 7 04-18-2007 11:36 PM
1999 Tahoe Passlock Problem rsqdiver Tahoe 0 08-05-2005 06:15 PM
