Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-29-2003, 03:52 PM
marty98GC marty98GC is offline
Airbag Indicator Light Stuck On (HELP!)
One day under normal driving conditions the Airbag indicator light on the dash came on and has been on ever since. Any ideas on what this could be? Any easy things to check such as connections?
Thanks in advance, Marty
Old 11-18-2003, 01:05 PM
Potis Potis is offline
Re: Airbag Indicator Light Stuck On (HELP!)
I've got the same problem (and more!). When my airbag light comes on, and I shut the car down, it won't start again because the keyfob won't disengage the immobiliser. Have had control module unit changed but it hasn't worked. Any help would be fantastic.
Phil
Old 11-18-2003, 01:16 PM
Potis - Airbag light issue reply
Hey sorry I won't be of much help.... My issue was solved with the module replacement. The only problem I had was that the light remained on after starting.
Marty
Old 07-29-2004, 10:30 PM
roybliz roybliz is offline
RE: Airbag Indicator
I had the same problem and the reason was the fuses that are used are grouped together in the fuse box and they were not pushed all the way in.
Old 07-31-2004, 10:02 AM
craig69 craig69 is offline
I eventually had to take mine into the dealer... something to do with the airbag... needs to be re-inflaited..
Old 07-31-2004, 10:29 AM
try this out http://www.autozone.com/servlet/UiBr...l&Parameters=7
Old 08-04-2004, 09:03 PM
glass glass is offline
I found that disconecting the battery fixed my airbag light problem on reconect
96 PA indicating lights Knox cnty resident Park Avenue 0 07-08-2010 01:03 PM
Problems with Airbag Indicator Light ShawnM3 M3 0 06-06-2007 04:23 PM
Airbag Indicator Light slimhall Montana/Montana SV6 5 12-13-2006 02:29 PM
98 windsar airbag indicator light fordman101 Windstar 3 02-12-2006 08:39 PM
93 Honda Accord gear position indicator light stuck in "P" millerman1 Accord/TSX/Accord Hybrid 3 03-31-2005 02:36 PM
