Old 12-04-2001, 11:45 PM
j.fuggi's Avatar
j.fuggi j.fuggi is offline
interior help.. removing pieces
i posted this on the old PH but no one has time to click submit 90 times... so....
my car is in the shop so i want to remove my tweeter pods, right side AC vent and my doorhandles for painting while i wont be driving it. how would i go about removing each of these? i will be buying a helms manual soon, but my nearest barnes and noble doesn't carry it for my car. i don't want to force anything too hard and break it.
(btw, i am painting more, but i already got that off easily. in case you thought i'm only painting a few things. )
i have a 95 civic ex
thanks
» Supercharged 2006 Honda Civic Si Coupe
» Info | Teaser Video | Dyno Video | Dyno Graph
Old 12-04-2001, 11:52 PM
Rice-Rocketeer Rice-Rocketeer is offline
Actually I did respond:
I have no idea where the "tweeter pods" are, Us Dx'ers didn't get such luxuries but the right hand side AC Vent is the most delicate and pain in ass thing to remove. If you don't know how to do it, you WILL break it. I've broken it, I've had friends break it, don't try it or have LOTS of patience. As for the door handles, the plastic piece behind the actual handle can be easily removed by unscrewing the phillips head screw at the top of it, but the actual handle that you use to open the door are screwed to the door and have rods attached to them that are used to unlock to the door via the locking mechanism. You need to remove the whole door panel, then the plastic, then screws, then rods, then you got it.
Lookin at my gucci, it's about that time...
Old 12-04-2001, 11:59 PM
j.fuggi's Avatar
sorry.. i know you posted but i was seeing if anyone else knew a better way to get the vent off and tweeter pods. the door panel isnt very easy either.
Old 12-05-2001, 02:27 PM
CivicRacerX's Avatar
CivicRacerX CivicRacerX is offline
Send a message via AIM to CivicRacerX
Well most panels are, understandably, not designed to come off easily. I know my 99 EX has little metal retainer clips all over the place, and it's realy easy to snap them off if you aren't really careful and patient about removing the vents, not to mention an actual door panel. My advice is to order the manual and just wait, because the headaches your likely to cause yourself in the meantime aren't worth the small to moderate amount of progress you'll make.
96 Honda Civic Daily - H22 Swap
82 Renault R5 Weekend Runner - Nearly Stock
83 Renault R5 Track Car - 13:1 CR, Archer Cams
Old 12-05-2001, 06:19 PM
j.fuggi's Avatar
thanks... gotta wait til i get my paycheck! got my car back today. new brake pads, oil change, and fixed some seals and bearings. yay for me
