Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 09-29-2003, 02:49 PM
speedyvic speedyvic is offline
86 si head still good?
Okay, I have an 86 crx si that needs a head. I found one at the junkyard and I was told that the reason it was there was because it blew a head gasket. So, what I want to know is....should it still work okay or could it have major problems? I know that there is a possibility that it could be warped but I am not worried about that, I will just get it ground down. Anyways, thanks for the help
Old 09-30-2003, 12:25 AM
DavidovSpeedWRC DavidovSpeedWRC is offline
Send a message via AIM to DavidovSpeedWRC
It should be OK to use as a quick fix, especially if you have means to mill it down a little.
When the headgasket blows, the motor just loses compression and will not run usually the engine parts are salvagable.
Check the head for bent valves, worn seals, or anything else goofy looking.
Old 11-23-2003, 10:13 AM
Imikto Imikto is offline
Re: 86 si head still good?
Yeah junk yard fixes are usually ok for quick fixes. the only real problem with doing that is if you find out its no good after you've taken all the time to put it in. I just got a transmision from a salvage yard and put it in a subaru and it works fine. maybe take the head to a mechanic and have him take a look at it to make sure its ok
New heads, still runs hot foreman72 Lumina 6 06-09-2007 01:30 AM
Old R/C, still good... omicron Remote Control Cars 2 10-20-2003 07:24 PM
Combat kit? Still good? CraniumDesigns Exterior | bodykits | Lighting 1 04-27-2002 03:18 PM
Get while the gettin is still good kris COMPLETELY off-topic 6 10-08-2001 12:47 PM
