Old 09-29-2003, 01:34 PM
PunsIntegraLs PunsIntegraLs is offline
Unhappy amp wire problemmm???
i got a 4 channell 800 watt amp. the wires that go to battery were cut on both sides of the fuse. Can i just twist these together with and use electrical tape, or should i solder them.
Old 09-29-2003, 01:42 PM
dvela85 dvela85 is offline
i dont know anything about soldering but you can use electrical tape to connect them
Old 09-29-2003, 02:35 PM
esp's Avatar
esp esp is offline
Send a message via AIM to esp Send a message via MSN to esp Send a message via Yahoo to esp
Re: amp wire problemmm???
u still need the fuse, believe me that if u want this to work well, go to radioshack and get a inline fuse block that u can connect both ends of the wire to.
*RIP* Integr8 aka Ryan *RIP*
5/29/03
www.fotki.com/esp
THIS OG IS GONE retired for good. peace yall. create a crew for me
Old 09-29-2003, 04:24 PM
Buzz1167 Buzz1167 is offline
Send a message via AIM to Buzz1167 Send a message via MSN to Buzz1167
You can just connect them with tape, but thats not the greatest idea, beucase for 800watts, its probably a pretty big wire, and it can get hot, might melt the tape or just come loose. Also, if it comes apart, it could fall down and short it self on the car body, screwing up alot of sh&%. So whatever you do, make sure its a solid connection, and its not going anywhere. You could always put a crimp connector on both sides and tape around that, if you can find one big enough. Soldering would be the "best" way to fix it though, so if you can, do it that way.
Buzz1167
Jon N
AMP/Speaker wiring in cooler boom box Chupacabra111 Car Audio 6 12-20-2010 06:29 PM
Amp wiring help dfaubs Jetta/Vento/Bora 2 07-08-2002 12:21 PM
amp wiring...how to white97ex Car Audio 13 02-21-2002 10:26 PM
firewall hole for amp wiring? bump909 Audio/Security 10 08-22-2001 07:27 PM
