Old 09-28-2003, 10:32 PM
bryan763 bryan763 is offline
Unhappy 96 taurus help! Stiff Power Steering
1996 ford taurus GL 3.0l
Power steering becomes very stiff, do not completely lose but very hard to turn wheel, after exceeding speed of about 30 mph. If you stop the car, shut engine off and restart, power steering returns (as if a solenoid was stuck). Changed power steering pump/res, Return side hose and filter (dealer parts). Is there a speed sensor for steering that could be bad? I was told that the rack needed changed, $500+ damn!
I also have an anoyance problem with the transmission. When I come to a quick stop, the transmission bucks forward as if a slow downshift. Took to a transmission shop and they found nothing wrong with the transmission and said it was a bad speed sensor?
Old 10-01-2003, 05:14 PM
Sam I am Sam I am is offline
Have you been flushing the oil on the Power steering and the transmission? You gotta do that once a year if you don't want trouble.
Old 12-08-2003, 09:33 AM
Wirenut Wirenut is offline
I am having the same problem with my power steering. It works fine when I first start the car, but then it gets very stiff. I've changed all of the hoses, pump (twice) and the rack and pinion.
Could the power steering pressure switch cause this problem?
Old 12-08-2003, 08:20 PM
Whymelaugh13 Whymelaugh13 is offline
Re: 96 taurus help! Stiff Power Steering
how do you flush the power steering?
Old 12-12-2003, 12:39 AM
Bryan C. King's Avatar
Bryan C. King Bryan C. King is offline
Send a message via AIM to Bryan C. King
Your Power Steering Rack is going south, time to replace it........
Old 12-13-2003, 09:31 PM
Unhappy
It was a faulty GEM module.
Old 02-17-2004, 05:52 PM
Blackvisor Blackvisor is offline
whats a GEM module?
Old 02-17-2004, 11:34 PM
Re: Re: 96 taurus help! Stiff Power Steering
Originally Posted by Blackvisor
whats a GEM module?
It's a "Generic Eletronic Module" and it is located behind the fuse box.
Old 03-20-2004, 11:44 PM
jim12051 jim12051 is offline
Send a message via Yahoo to jim12051
I don't know if this will help or not but worth trying it fixed my int power steering problem....replace the transmission range sensor also known as the nuteral switch. hope it helps..
Power steering flush Windstar 98 - No place to work serge_saati Windstar 9 11-05-2015 08:02 PM
Problems with Acceleration and now Power Steering dbhynds '01-'05 Civic 5 01-06-2010 07:41 AM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
92 Cutlass Supreme Power Steering Hose Mikey_G Cutlass Series 4 11-23-2009 01:47 PM
2000 PA Power Steering Fluid Check buickultra2000 Park Avenue 2 11-12-2009 10:12 AM
