Old 09-28-2003, 09:05 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
How Much Boost...
How much Boost could a stock B16 take on 91 octane gas.
I plan on running stock Ignition system with the exception of Zex Spark Plugs. The fuel system will consist of a 255lth Fuel Pump, 450cc injectors, AEM Fuel Rail & FPR.
I plan on running a T3/T4 turbo the wastgate comes with a 8psi spring... is 8psi too much ?
thanks
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 09-28-2003, 11:19 PM
VeNomGSR VeNomGSR is offline
Send a message via AIM to VeNomGSR
on a b16a psi is the highest id go...id run 6psi on the street to be safe...u got a nice fuel set up goin there though...definately good enough to run more boost...but i think u should build up some internals first if ya gonna run 8 or higher....JUst to be safe
Old 09-29-2003, 01:28 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
8 psi is fine. 7 psi is the most common ive seen ran tho.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-29-2003, 05:25 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Stock b16a's can handle 10psi safely with ample fuel and GOOD TUNING, but 8psi is good for the street. As for you fuel system, ditch the rail. Your stock fuel rail can support up to 500hp. Also I see you are planning on using 450cc injectors, your car is going to run rich unless you get some kind of engine management, the stock ecu cant idle those very well. That will also keep you from needing an adjustable fpr. Between the rail and the fpr you can save about $300 and put it towards an engine managment device of your chosing, I recommend hondata (base $450) or at least an afc. At the VERY least an fmu although it will still idle rich and shitty with the 450cc.
Old 09-29-2003, 05:34 PM
Kunundrum's Avatar
I was thinking Apexi VAFC... thanks for the advice on the Rail and the FPR I did not buy those yet.
Old 09-29-2003, 06:55 PM
The apexi setup is what i use now. It is pretty good for up to 10psi with the 450cc's. I would still recommend getting it dyno tuned with the afc. You won't have precision tuning like you would with most other EMS but it's good on the street and for the price. In my experience, I would recommend just getting the apexi safc rather than the vafc. Changing the vtec crossover isn't going to net you much of anything under boost worth the extra money.
Old 09-29-2003, 09:11 PM
boostlee boostlee is offline
you should be able to run up to 10psi if properly tuned, make sure fuel is there. upgrading your cooling sytem and a oil cooler can help to keep reliable
Boost Lee
1995 Honda Prelude SE Turbo
http://members.cardomain.com/boostlee
Old 09-29-2003, 09:42 PM
HEVY_HITTER HEVY_HITTER is offline
Send a message via ICQ to HEVY_HITTER Send a message via AIM to HEVY_HITTER
so if i were to build a b20/vtec sleeved, pistons, rods, cams, etc.....with drag 3 turbo.....what should i have in terms of fuel and engine management? i was thinking a hondata s200, 510cc injectors(too small?), aem feul rail, what type feul pump?, and what else for my fuel and engine management? what all would i need in you guys' opinions?
thanks alot
Old 09-30-2003, 07:01 PM
Re: How Much Boost...
thanks alot
Well with a setup like that, you could run 20something psi tuned so you would need a good standalone. The hondata is a great choice for the money, but from all the feedback I have heard, people really like the aem ems. A bit pricey but I am told its worth it. As for the injectors, I'd definatley go bigger if you want to run some serious boost. You might want to look into upgrading the rest of the head with a b20 setup like that. I'd go with the aem rail at that point and a 255lph in tank should be sufficient with an inline to be safe. If it were my fuel system, I would do all new fuel lines and everything.
Old 10-01-2003, 03:01 PM
thanks for the input man
Old 10-03-2003, 05:06 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Re: Re: Re: How Much Boost...
Originally Posted by maxspeedhonda
Sex should be like a riced out civic; slow, obscene, and loud enough for the neighbors to hear...
First, I wanted to tell you that's one of the funniest sigs I've seen on here, lol. Second, I just wanted to say you know your stuff when it comes honda's as well as turbocharging, keep up the good work. It's always nice to see threads were people are helping other AF members out instead of bashing on them.
Old 10-03-2003, 07:26 PM
Re: Re: Re: Re: How Much Boost...
Thanks for the props but I can't take all the credit. I have learned mostly from experience whether the easy way or the hard. But there are quite a few very knowledgable people on AF with various kinds of cars that are just as willing to help. I come here for help so in return I help when I can and thats what it is all about.
Old 10-05-2003, 02:16 AM
Honda God
Re: Re: Re: Re: Re: How Much Boost...
Yea, I hear you. I help out people when I can, I figure, pass the knowledge you know along when you can. You know? Like you said, help out since we look for help on here. Whether you look for help here or in other information meduims, it's always nice to help out someone when you can and pass the knowlegde along.
Old 10-06-2003, 10:22 PM
fnkdrspok fnkdrspok is offline
Send a message via AIM to fnkdrspok Send a message via MSN to fnkdrspok Send a message via Yahoo to fnkdrspok
I know this is a little late but since we installed this kit on my car, my car leans out at after 5 psi of boost so I have to do all of those things to keep this car from blowing up. I was thinking some DSM injectors from an old eclispe (blue top 450 cc's), the resistor box that converts them, a VAFC or SAFC, and maybe a FPR (AEM). My question is, if you can explain why tuning your vtec lower will not be worth the extra little money that it costs for the VAFC?
And should I use some used injectors from a turbo eclispe? Now let's remember, practally this whole kit is used so suggesting new parts will not help me any. I just want to reach 8-10 lbs without leaning out. Can somebody help me?
FnkDrSpok
95 Civic DX Coupe D15B7
Aerodyne/Bell Turbo rated at 250 hp max
DSM HKS BOV
Big Ass FM Intercooler
DC Sports Catback Exhaust
SAFC-II w/DSM 450cc Bluetop injectors
MSD SCI Ignition
MSD Distributor w/Blaster Coil
MSD 8.5 mm wires
NGK V Power Spark Plugs
Venom 400 Performance Module (which I'm selling)
Pics of current setup: http://photos.yahoo.com/prettyboy_bawler
Got it tuned, having mad fun running 8-9 psi.
B18C1 is on the back burner as I play with this setup for a while.
Old 10-07-2003, 06:50 PM
I got my injectors of a 98 or 99 gst for $50, has them balanced and flow tested with near perfect results. You do need some sort of ems and a adjustable FPR is not necessary. I didnt say lowering the vtec crossover wouldnt have any effect, just not eough to warrant spending the extra money. Hell even the NA guys will tell you to save your money. Leave it where it is intended to be set at unless you are prepared to spends lots of time on the dyno.
