Old 09-28-2003, 06:01 PM
POScar49 POScar49 is offline
broken oil pump
gotta replace my oil pump nebody kno if i need to take off the tranny before taking off the oil pan or can i just take off the oil pan?
Old 09-28-2003, 06:57 PM
91zc 91zc is offline
You don't need to remove the transmission to remove the oil pan. You however will need to remove the flywheel dust shield that is attcahed to the trans with a few bolts.
91 civic 4dr
b16a
14.8@94
Old 09-28-2003, 07:00 PM
HONDABOND HONDABOND is offline
Damn... That sucks! What engine?
White folk eat noodles too.
Old 09-28-2003, 08:02 PM
ok. do i need to torque nething wen i put everything back together?
Old 09-28-2003, 09:04 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
The oil pump is on the other side of the motor...When I replaced the oil pump on my d16a6, all I did was remove the oil pan, remove the harmonic balancer pulley, removed timing belt/lower timing belt cover, and like 8 bolts and the oil pump comes right off...
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 09-29-2003, 05:37 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
yup red is right. take off oil pan. take off the pulley with timing belt and the gear adn everyhitnd down to the oil pump. unbotl oil pump and pull off. easy simple takes alitl bit time
Team Lonely Drivers
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
