Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 12-04-2001, 10:51 PM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
Question neverending search for camber adjustment
I've heard people drill holes and weld washers in the "connecting arm", but has anyone recently found anything else out? Also, I haven't noticed anyone talk about the Stillen 300ZX rear camber adjusters. Will these work? They at least look like they would work.
nightmaR3Z
Old 12-04-2001, 11:22 PM
T4 Primera T4 Primera is offline
Dude, check out www.prestigeautomotive.co.nz They have front camber kits for around US$160 + shipping.
These kits consist of two replacement upper control arms fitted with eccentric bushes (urethane)at both ends. One bush is more eccentric for coarse adjustment while thother is less eccentric for fine adjustment at wheel alignment time.
Geo (P10DET) was looking into these and got a reply from them but I don't know if he remembered to write back again. There is quite a lot of stuff we can get here that you guys seem to have trouble finding.
Patrick (pche059) has a set installed on his P11 and reckons they work very well.
Also, if you e-mail STOCKS, [email protected] , they can supply eccentric front lower control arm - rear bushes for CASTER adjustment as well.
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 12-05-2001, 12:57 AM
nis.k.a.'s Avatar
SHOOOOT. Since I don't live in NZ, can you get these for me? Or is it easier for me to order from them directly? I would need to get them next month; you know Christmas is crazy for sucking up money. Regardless, thanks for the info.
nightmaR3Z
Old 12-05-2001, 01:45 AM
Try contacting them and see if they can ship to you. I'm pretty sure they can, but if you have no joy, let me know and I'll try to help out.
Getting a reply may take awhile, especially at Xmas, but that should work out ok for you anyway. I had to ring up and remind them to answer Geo's email before as they were busy with the WRC NZ round.
-- Bertrand Russell
Old 12-06-2001, 11:25 PM
P10DET's Avatar
P10DET P10DET is offline
Originally posted by T4 Primera Geo (P10DET) was looking into these and got a reply from them but I don't know if he remembered to write back again. There is quite a lot of stuff we can get here that you guys seem to have trouble finding. [/b]
Yeah, I've just been lame lately. For the past two months I've just been so buried I haven't hadn time to half the things I need to get done. I still need to check the mounting of the Primera bumper cover. It's looking like after Christmas at this point. But, as I'm an accountant, that will bring us into the audit season, so life will continue to be crazy.
Shoot me now.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 12-07-2001, 04:02 AM
Yahnozha Yahnozha is offline
Send a message via Yahoo to Yahnozha
Question on the camber kits, how much of a drop in the front end do you have to go before camber becomes a problem and you need the kit. Im not planning on going too low, but curious none the less.
Or would it just be a good addition to keep even wear on the tires???
P@
www.customsteel.com
P@ - www.customsteel.com
Red 99 G20(t) / UR 2 piece / JWT POP / HS CAI / WW Lip / HS Header / Greddy Evo / S3 cams
Old 12-07-2001, 07:46 AM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
You wont need one if you stay conservative. ...not that there is one for a P11. And if there was, I dont think it'd be too affective. Camber kits for multilink suspensions are a crock!
Anyhow, I know for sure you can go 2" w/o camber problems on P11's. At that point you'll have bigger problems, ie.. bottoming out. 1.5" to 1.75" is about the most you can go to keep it decent.
Old 12-07-2001, 09:27 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
I don't think so. Even though technically the camber should remain consistent through out the travel range I'd still like to put a little negative camber on the front.
Old 12-07-2001, 12:31 PM
b-b00gie's Avatar
Banned
Whether you think the car needs more or less camber is an opinion and your choice. I think I'd agree with you though.
However, a 'camber kit' for a mulitlink suspension is a crock of sh*t. By design, it just wont work properly.
You would need to come up w/ another way to adjust your camber.
Old 12-07-2001, 02:38 PM
G-Forces's Avatar
Banned
You might be relating to camber kit ot camber plates. In that case yes. But a camber kit that actually changes teh camber is still a good deal. Look at the 'camber kit' Stillen sells for the 300ZX. While it won't work in the G20 that same idea would work with the G20.
Old 12-07-2001, 02:50 PM
b-b00gie's Avatar
Banned
Not sure what the 300ZX one looks like..
I was referring to the one like they offered for the P10.
Old 12-07-2001, 03:11 PM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
just letting you guys know that Cusco has always had an adjustable lower control arm for the P10
Luke C.
GDA Power!
Old 12-07-2001, 04:22 PM
G-Forces's Avatar
Banned
Whoa, since when? And why wouldn't it work on the P11?
Old 12-07-2001, 04:30 PM
nis.k.a.'s Avatar
I believe he's referring to the replacement arm (the modified upper wishbone if you will) that is adjustable. This is the same as the Stillen one for the rear of the 300. Although it doesn't change the shock position like plates, it still changes the camber. Seeing as how it's not that pricey and it is a little bit of insurance, I think it's worth it. How much is that Cusco one, probably pretty pricey seeing as it's a Trust product.
nightmaR3Z
Old 12-08-2001, 12:28 AM
Did you read my post at the top of the thread before you wrote that:huh:
If you meant camber 'plates', then I agree, but a kit that effectively changes the length of the lower control arm or third link WILL alter camber.
-- Bertrand Russell
