Old 09-28-2003, 05:07 PM
Slacky Slacky is offline
Send a message via AIM to Slacky
B16 acting slow..
Specs- 1990 CRX b16, Airmass Headers, Intake, performance muffler.
The past 2 weeks or so it seems like my car is missing some power. It was running great after I changed the oil, but a little bit after that it's starting to bog down. When I floor-it there is nothing at the end of the pedal. Once I get to a certain point of giving it gas, it wont increase anymore, like there is some play in the pedal, but not when you first push the pedal, when at the end of the pedal. Maybe I'm just getting used the speed and craving more, but this b16 doesn't seem to be as fast as it should. I was racing a Cavalier(some fag w/ a body kit, think it was a z24) down the highway, and we nailed the gas at about 60 mph and i had nothing there...and he pulled on me. I hear about people with b16's and nailing the gas and the car just breaking open, not mine...
I need new plugs, but I don't think thats it. I was thinking maybe my fuel pump is going out, but I'm obviously a novice, and just starting to learn this engine, So any help would be wonderful...
Old 09-28-2003, 07:28 PM
98-integra 98-integra is offline
it might be the fuel pump or maybe the injectors could be cloged or fuel filter but i dont think it would only happen when you hit the gas hard
Old 09-29-2003, 01:13 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
have you recentley done anything with the timing? timing belt change? i was just thinkin that maybe the timing is off. You might want to check the distributor (rotor, etc). Run some injector cleaner through the system and see if that helps too.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-29-2003, 01:17 AM
No timing belt change, replaced the alternator about 2 weeks ago. Just put some injector cleaner in yesterday. Haven't checked the timing, I'll check it,...I also have a idle fluctuation problem, don't know if they're related
Old 09-30-2003, 06:56 PM
civicswap civicswap is offline
boging down
Sometimes it could deal with the heat in the weather, cause my car does not like the heat, it likes the cold.
Old 09-30-2003, 11:48 PM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
If You Arent Feeling The Power After The Oil Change Maybe You Didnt Put Enough Or To Much.
MODS: Motor :jdm b16 block, itr head, skunk 2 cam gears, msd ignition, intake, exhaust, straight pipe, skunk 2 ecu. act race clutch Suspension : grnd cntrl coilovers, 4 way adj shocks , spoon strut bar, skunk 2 sway bar, itr control arms, energy bushings misc. : super nice jdm seats, momo detachable steering wheel, Jdm clutster, Spoon Cf duckbill wing, vision smoked amber turn signals. COMING VERY SOON IN DAYS LS vtec ARP ROD BOLTS HEAD BOLTS AND 75 SHOT OF GIGLE JUICE look in my galler
Old 10-02-2003, 08:37 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i agree check your oil level, VTEC only engages when there is enough oil in the system.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-02-2003, 08:54 AM
T!mmy T!mmy is offline
Send a message via AIM to T!mmy Send a message via MSN to T!mmy
Ok I know I am new to all this but on a dune buggy we fixed up we were having this exact problem. There was idle fluctuation and then when we'd really get on it with the gas it wouldn't *romp* like it should.
Cause: Our timing was off.
Just my I could be completely wrong.
The Dr. tells me too much masturbation is unhealthy...So when is "too much" masturbation "too much"???
Check out our car club site which I made http://www.almostperfectcc.com
Originally Posted by 18c5sol94
we go from a stop he pulls a little on me (only cause i can't keep the wheels on the ground)
