Old 09-27-2003, 11:56 PM
MXrider22 MXrider22 is offline
COST$... H22 swap vs vtec head swap
I would like to know which would be less expensive/pain in the ass... a complete H22 engine swap into my 92 prelude Si... or a H22 head swap onto my H23
Old 09-28-2003, 01:49 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
well the less expensive route would be to go with the H22 head which is about $400, but the more reliable and better swap to do would be the full H22 swap, which can be bought for about $2400 or so...
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-28-2003, 10:54 AM
Re: COST$... H22 swap vs vtec head swap
Are you sure about this? i found this list of things that are required to do the swap and it looks like a more than 400$ list
1. VTEC head, complete: cams, gears, rockers, valve cover.
2. VTEC timing belt- VTEC has more teeth on the belt than the Si does.
3. VTEC water pump.
4. VTEC auto hydraulic tensioner for timing belt.
5. VTEC manual tensioner.
6. VTEC head gasket.
7. VTEC lower, most inner crankshaft pulley;
8. VTEC intake manifold ('96, throttle body has sensors which you need to use).
9. VTEC exhaust manifold
10. VTEC ECU/ECM.
11. VTEC spark plugs and wires.
12. VTEC water pump pipe (black pipe that runs behind the head from the water pump to thermostat housing.
13. VTEC injectors - if you don't change these over, then once you plug in the ECU/ECM you will keep blowing the 'EAT ECU' fuse when you crank/start the car.
Also remove the oil control orifice plug on the h23 block. should be right in the middle on top of the block.
hope this helps. got it at www.hondaplex.com i am currently doing one right now and me and this guy at hondaplex have put together a manual on how to do this conversion.
Old 09-29-2003, 01:31 AM
90CRXZCSi's Avatar
well if you want it to be a less pain in the ass, the full H22 swap would be the way to go.
anyone have any info on a f22a non-vtec head swap to a f22b sohc vtec head mox4_2001 Let's get Technical! 3 06-27-2004 07:46 PM
COST$... H22 swap vs vtec head swap MXrider22 Engineering/ Technical 0 09-27-2003 11:54 PM
COST$... H22 swap vs vtec head swap MXrider22 Prelude 1 09-27-2003 11:52 PM
h23 vtec head swap noble4ws Prelude 3 09-01-2002 08:39 AM
DX With a EX VTEC Head Swap essex Engineering/ Technical 8 06-07-2002 02:07 PM
