Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-04-2001, 08:41 PM
JGM JGM is offline
4 Bolt To 5 Bolt Wheel Whats it going to Take?$?
4 Bolt To 5 Bolt Wheel. Whats it going to Take? and is the wort the Money? I Love the Acura CL Type S Wheels. I think they would look great on my 01 Accord Coupe. The only problem I bought the 4 cyc for the stick and got stuck with the 4 bolt wheels not the 5 bolt that comes on the V6.
Any One know the maker of the wheel or if it comes in a 4 bolt patern
Thanks
Old 12-05-2001, 05:44 PM
EliteAccordPH's Avatar
EliteAccordPH EliteAccordPH is offline
It'll be expensive because you'll have to convert the front and rear.
Old 12-05-2001, 08:23 PM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Actually there are converter plates that fit over the lugs to make it into a 5 bolt, I'll have to do some research on that.
Old 12-06-2001, 02:55 AM
natcc99's Avatar
natcc99 natcc99 is offline
Re: 4 Bolt To 5 Bolt Wheel Whats it going to Take?$?
personally, I think you are better off just buying a different set of rims that look like the ones you mention.
There are thousands of different rims out there and I'm sure one of them will look like the ones you like.
It will save you a lot of trouble trying to convert the lug pattern of your car.
If you wish to do it, it's going to take some work.
However, it shouldn't be difficult.
You will probably have to take some parts from a V6 Accord and simply swap them over to your car.
I'm not sure if it's a direct bolt on, but I'm sure it's VERY simular.
What will happen is that you will have to replace the rotor and the "mount" which it is assembled to fit on the car.
It sounds a little easier then done; however, it's not impossible.
My good friend has a Saleen Mustang from the mid 80's
He changed his rotors and they are HUGE.
Anyways, the new rotors are a 5 lug pattern instead of the stock 4. Thus he did a few changes and get the new rotors on and he also go new rims.
It just comes to show that it can be done.
Good luck.
I would check with parts from a V6 Accord and see how expensive they are and if they both on a I4 Accord.
Purehonda Moderator since March 2000
Purehonda Member since Feb 2000......and still counting
http://www.sounddomain.com/id/natcc99
Old 12-10-2001, 10:03 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
From what I've heard, converting from 4 lug to 5 lug requires some axle swaping, at least that's the case with Integras and Civics, they just swap out to the ITR or CTR axle pieces to get the 5th lug on their car. I dunno how you'd go about doing it on your Accord, but I assume you'd have to swap out for the Accord V6 axles providing they will fit. I hear the conversoin can cost something around like $2000 for the change out. But a cool one it is.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 12-13-2001, 05:42 AM
greg severson greg severson is offline
DONT USE ADAPTER PLATES !!! THEY CAN BREAK UNDER HARD DRIVING CONDITIONS IVE HEARD. I WOULDNT RUN THEM ON MY CAR. SAVE ALLOT OF TIME AND HASSLE & PROBS. MAYBY EVEN MONEY AND FIND SOME WHEELS TO FIT. IF YOU CONVERT THINGS AROUND TO MUCH, LATER IT WILL BE HARDER WHEN THINGS NEED TO BE REPLACED LATER DOWN THE ROAD TO GET THE CORRECT PARTS WITH OUT SOME PROB. GOOD LUCK!!!!!
Old 12-13-2001, 05:57 AM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
thanks for typing in all caps, because I wouldn't have been able to read your message normally.
Old 12-13-2001, 08:44 AM
HONDA_99 HONDA_99 is offline
4 to 5 lug swap is not worth it.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
