Old 09-27-2003, 06:28 PM
d12100r d12100r is offline
Angry Major Civic PROBLEM!
Hey,
I have a major problem with a 1993 civic ex sedan. Its only 15 mpg! the tank fills up at about 8.5 gallons and this vehicle cannot pass inpection. Ive heard that no civic is good. There was a brand new civic for inspection that did not pass either and it was new. they sent it back to honda and the manufacture and they had to replace everything. anyone else have this problem?
Old 09-27-2003, 06:57 PM
damir831's Avatar
damir831 damir831 is offline
Banned
Send a message via AIM to damir831
Hmm that's weird. In illinois, they don't test vehicles that are under 3 years old. One time, I drove 180 miles and I only put 4 dollars woth of gas in the tank (about 3 gallons)
Old 09-27-2003, 07:02 PM
Milliardo's Avatar
Milliardo Milliardo is offline
Send a message via AIM to Milliardo Send a message via Yahoo to Milliardo
Lightbulb
That is strange. Over here, the Civic, as well as other Honda vehicles, regularly pass emissions. It's actually Toyotas who are notorious for their high failure rate. It's almost sure that a Honda will pass a test, and testers here sometimes don't even bother testing a Honda because they're sure that it will pass anyway. On the other hand, they're almost sure that a Toyota will fail emissions.
Admin of PGamers Forum
1993 Honda Civic ESi (Sailor Mars)
My wish list--I need help in this project: http://pikarod.fateback.com/car3.html
Old 09-29-2003, 01:30 AM
sageuvagony's Avatar
sageuvagony sageuvagony is offline
Send a message via AIM to sageuvagony Send a message via Yahoo to sageuvagony
Well here in FL we dont have any inspections!
1997 Integra GSR and 1992 Civic LX
Old 09-29-2003, 01:33 AM
Jas_M Jas_M is offline
Banned
Send a message via AIM to Jas_M Send a message via Yahoo to Jas_M
Haven't had my '00 Civic tested yet, but my previous car was a '92 Camry and it passed its emissions tests with flying colors. Never had a problem.
Old 09-29-2003, 04:44 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
15MPG on a civic? Okay dude, Civics arn't that bad, it's something wrong with the car. NO civic running properly will get that crappy a mileage. As for honda's not passig DEQ? Never heard of that problem, unless they are modded up the asss with parts that won't pass inspection (aka big-ass turbo, no cat, etc) But thats not cuz it;'s a honda, thats cuz of how it was modded. As you your 93ex, 15mpg is waaaayyyy under what you should be getting. I am not suprised you didn't pass. With that MPG, something is very wrong. it should be getting like 24-28mpg, 15 is way under. Bad gas mileage and your tamk problem are evidence of a greater underlying problem. as for the tank part, maybe you have a s-load of slugde in the tank, and that has clogged the injectors and engine and f'd up emissions. I don't know though, thats just a stab in the dark, but thats not a "honda" problem. Whoever told you that about emissions failing was either a)wrong, or b) refering to illegelly modded honda's not passing, but didn't realize that was why they don't pass. As for the engine and gas mileage. Again, not a Honda problem, it is instead, evident that your honda has a problerm, most likely from abuse, neglect, shitty gas use over a long period of time, or a combination of the three. the 92-95 gas tank holds 11.9 gallons of gas, so if your fills at 8.5, either you has a shitload of sluge in the tank or your gas gauge is way off, maybe sluge in the tank (taking up space, so you get less gas) f'd up the sensor in the tank.
Old 09-29-2003, 08:19 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I would check your spark plugs and wires first. That is the cheapest and easiest thing to check. Make sure your tires are all inflated to around 35-38psi. Make sure your ignition system is working properly too (disributor, battery, etc....)
That does not sound right
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 12-19-2003, 06:44 PM
civiclover94 civiclover94 is offline
Re: Major Civic PROBLEM!
dude your cars fuel injecters are either broke and arent timed right so it is like pour gas into your cylynders or you have a hole in your gas tank! lol
Old 12-20-2003, 12:18 AM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
They test vehicles in Illinois?! lol, glad I live south of Chicago... no testing goes on around here! 15 mpg is terrible! My car knocks down like 27 with spirited in town driving and about 34 on highway trips. I have a '94 EX coupe w/ a 5 speed. I have heard that on occasion Honda injectors will get stuck open or closed. In fact this happened to my g/f's car about 6 months ago and it ran like hell. Do as CivicSiRacer said and change your plugs and wires to start with, and when you are changing the plugs look at them closely. Check them one at a time and remember where they came from. If one plug looks drastically worse (more deposits, darker color) than the others then that would point to a possible injector problem. As far as only needing 8.5 gallons to fill up that is probably just because you aren't using all of the gas in the tank... I find my gas gauge to be at least somewhat unreliable, I have run my car at least a full needles width under the empty line and still not put in over 10.5 gallons.
LS1 RX-7 Zoom Zoom
Old 12-22-2003, 03:35 AM
Honda God
Re: Re: Major Civic PROBLEM!
I have found this to be true on many 5th gen civics I know of.
Old 12-22-2003, 11:04 AM
LilCivicChick LilCivicChick is offline
Yeah, your car definately needs some help. Yay for $13 fillups! I think I get like 28 mpg or so.
Old 12-23-2003, 04:53 AM
Honda God
Hey, I just noticed in your profile you're from the portland area also....it's always nice to see someone from the area on AF....and by the way, welcome to AF.
Honda Civic problem :( Awex89 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 02-10-2010 03:15 PM
Major accelleration problem, HELP!! HiFlow5 0 S-10 3 07-20-2004 09:06 AM
Major Printer Problems... omicron COMPLETELY off-topic 1 08-13-2003 07:16 PM
having major alighnment problems with Integra front brake conversion, HELP!! 91EF3ZC '88 - '91 Civic | CRX | Wagon | Shuttlee 9 04-24-2003 10:49 AM
Major electrical problems.... where to buy bigger alt.?? G20pimp General 10 01-03-2002 12:19 AM
