Go Back   Automotive Forums Car Chat > Dodge > General Discussion
View Poll Results: Is this possible for a daytona 89.
Smart? 1 33.33%
Originality. 1 33.33%
Never going to work. 0 0%
Add More? 3 100.00%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Old 09-27-2003, 06:27 PM
Whyjf Whyjf is offline
Send a message via MSN to Whyjf Send a message via Yahoo to Whyjf
Question Daytona 89 modification
I am removing the motor from my 90 daytona 3.0 and putting it in my 89.
I got the 90 from a junk yard and a savage title was unavailable. If anybody has any extra info. for this swap, it would be greatly apricieted.
I am also trying to put the 90 model dash into the 89. i have already put the center consul (and the hand e-brake in, but i can not put the dash in until i swap motors due to the trans. ratio for the speedometer. Any comments or corrections?
Old 09-28-2003, 10:09 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I can see your premis since the 90+ interior looks about ten time better than the 89 and below. However; why are you wanting to swap the 3.0L? Anyhow; you can do it. How had it will be depends on what engine was in the 89 to begin with.
Old 09-28-2003, 04:32 PM
reply
That's why i wanted to change the int. It looks so much better. The 89 had a mostly mismatched 2.5 motor in it and i wanted to have a bigger motor. The v6 was the cheapest and in the best condition ,so i thought. Sooner or later i should have the v6 up and running. Thanks for the help.
Old 09-28-2003, 07:20 PM
Polygon's Avatar
The Red Baron
Sure.
Since the old engine was the 2.5L you're going to have to modify the motor mount locations for it to fit. You will also have to swap over all the wiring and the trasmission as the transmission you have in there now won't bolt on. You can do it but it won't be easy.
Old 09-28-2003, 08:17 PM
PWMAN's Avatar
PWMAN PWMAN is offline
Polygon is right. You should stick with a 2.5, or even better get a turbo 2.2 in there. Thats where the real power is. Find a turbo 2.2(88-up T2) or even a turbo 2.5 would be a lot cheaper and you will be faster than dropping that 3.0 V6 in. The V6 requires more work, and the turbo engines require less and have WAY more potential. Add an intercooler and turn the boost up, thats 225 HP without any other mods besides opening up the exaust.
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
[email protected] MPH
Old 09-29-2003, 10:53 AM
reply2
i wanted the v6 because that is what i can afford without a lot of extras. The 2.5 is hard to get parts for because it is mismatched with other dodge cars. The parts are just slightly different and makes it hard to buy parts. I knew i would have to change motor mounts but that is easy compared to computer changes and wiring harnesses.
Old 10-21-2003, 09:25 PM
GTCandGTSturbo GTCandGTSturbo is offline
When you make the swap from 2.5l to 3.0, all of the engine bay harness will have to be swapped over. I would basically rewire the whole car as you will need all of the interior wiring for your interior swap. The door panels on the inside will also be very different. You may have to cut out the door skins and reweld them on the new car. Either that or have at it with the sawsall taking material off and add mounting points where nessesary.
Old 10-28-2003, 03:44 PM
Bazilisck311's Avatar
Bazilisck311 Bazilisck311 is offline
Send a message via Yahoo to Bazilisck311
what would you need to replace/upgrade if you were to put a 2.2L turbocharged in to replace an 2.5L TBI (normal aspiration)? Is there a high chance that you might trash the car in the change??
I want to upgrade from a 2.5L to a 2.2L or 2.5L turbocharged (2.2L i guess are easier to get ahold of and are a bit faster than 2.5L turbocharged, but i would go with 2.5L if i found it first) in a 89 Daytona ES
thanks for your help
Old 10-28-2003, 04:20 PM
Polygon's Avatar
The Red Baron
Re: Daytona 89 modification
What you would want to do is swap the entire turbo engine in as well as all the piping and tubing and of course the computer. It should be a direct swap since the 2.5L and the 2.2L have the same mount points. It should be very easy considering you know what you are doing but it should drop right in.
Old 10-28-2003, 08:05 PM
PWMAN's Avatar
What you want to do is go to www.thedodgegarage.com Gary donovans website. He has that whole swap layed out. It's much easier to change a TBI car than a carbed car, so since you have TBI you're all set.
Old 10-28-2003, 09:21 PM
das what i like to here thanx for the help guys :-D
so you dont need to replace the carberator or intake and exhuast manifolds? I cant find the guide at gary donavans web site, give me a link to the article
Thanks a bunch guys
(12s@120mph with a Daytona! WOW)
Old 10-29-2003, 07:41 AM
PWMAN's Avatar
Thats right, it wasn't the dodge garage, it was dereks garage:
http://members.rogers.com/derek.beland/
On the left side just scroll down until you see ''TBI to turbo''. And there you go.
Old 10-30-2003, 08:14 PM
have any off you guys ever done this conversion? He says that hes never actually done it before, it would be nice to get some info from someone whos done the conversion, incase hes missed something important..
Old 10-31-2003, 12:44 PM
86shelby_charger's Avatar
86shelby_charger 86shelby_charger is offline
Send a message via MSN to 86shelby_charger
Talking
I've done it, you need the turbo engine, the icu, and then theres a power module under the hood, 2 big plugs going in your intake somewhere, u need that box, the one for the non turbo is different, and you'll run into problems without it. u also need the underdash wirirng harness, and all the vacume lines and harness under the hood, and 4 vacume solinoids. If you have a donor car it's really easy, just look at whats there, take it off and bolt it on yours. As far as your interior goes, your guages will still work with the four cylinder. The transmission is the same for the v6 and the 2.2. the only difference was the bell housing, so the ratio is the same!!
Old 10-31-2003, 04:34 PM
gotcha, the only thing i dont understand is.. whats an icu, is it another name for the engine computer, or intercooller? He says on the guide if you use stock transaxle for a 2.5 TBI with a 2.2 turbocharged you'll smoke the tires very easy, cuase the ratios were set higher to compensate for the lower tourque, is this true?
ok so heres a list of what you said i needed:
turbo engine
ICU
power module
underdash wiring harness
all vaccum lines and harnesses underhood
4 vaccum solinoids
that it?
Car Body Modifications Beetleman General Issues 1 02-22-2009 03:28 PM
1986 N/A Daytona to a turbo 2 Daytona KingFiasco General Discussion 5 07-27-2003 01:10 PM
