Old 09-27-2003, 09:05 AM
chuckhatch chuckhatch is offline
turbo dx or ls motor
does any one know what kind of wheel horse a greddy turbo kit(no intercooler) kit on a 95 civic dx will put out????and does anyone know what a 5th gen hatch will run with a ls motor/ls trans and with a gsr trans....
Old 09-27-2003, 02:49 PM
hondaracer hondaracer is offline
Re: turbo dx or ls motor
I think its only around 35hp.... Not too impressive with a 95 civic motor. And a 5th gen hatch with a ls motor will run pretty god damn quick. My friend has one with a ls motor swap and some other mods and he's running the mid 14's....
Old 09-27-2003, 11:09 PM
what kind of mods does your friend have...?on his ls civic hatch...is he using a ls trans or a gsr trans?
Old 09-30-2003, 12:54 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Oh man, get the LS. The DX motor is 102 HP and 91 ft/lbs of torque. (flywheel numbers). The B18B1 is 142 HP and 127 ft/lbs of torque. Even stock, you'll notice a huge increase with the LS. Also, remember, the boosted DX is near its limit with a re-build, and the hp numbers still arn't better than the. The LS will give you more now, and much more later. Should you boost the LS later, you can boost it to 12psi on stock internals when tuned right. Thats over 250whp. You'd have to competley re-build a d-series to hit that, and push it to the limit. The LS will have you quicker now, and much more so in the long run. Plus, the turbo still doens't make the dx motor better than the LS. An LS with I/H/E is much much quicker than that dx motor. I have a B18B1 with that in my civic, and it hauls ass compared to the DX motor. And the added torque from the much greater displacement is a big big help. You will definatly notice it.
Old 09-30-2003, 07:58 AM
i probally gonna go with a gsr trans though the ls trans gears arte too long...and i would not be tuboing any time soon..so that would be better..
Old 09-30-2003, 08:40 PM
96HondaCivic 96HondaCivic is offline
a stock ls has 120 horspower to the wheels in a integra. Thats b18b1 engine code.
*- '96 Honda Civic Lx 4 Dr Auto -*
*- CAI 2.5in w/aem bypass -*
*- Invidia High Performance Cat-Back Exhaust -*
*- Suno Hyper Ground System -*
*- Front Upper & Rear Upper Strut Bars -*
*- Dc Sports Rear Lower Strut Bar -*
*- Tom's Lowering Springs 1.5in -*
*- 16X7 Konig Blatants w/ 215/45 Falken Azenis -*
*- Power Stop Slotted rotors -*
*- G-Force 5 Points Harnesses(Only using 4 points) For autocross -*
Old 09-30-2003, 11:44 PM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
Why Not A B18c ?
I G0t One And I Love It!
MODS: Motor :jdm b16 block, itr head, skunk 2 cam gears, msd ignition, intake, exhaust, straight pipe, skunk 2 ecu. act race clutch Suspension : grnd cntrl coilovers, 4 way adj shocks , spoon strut bar, skunk 2 sway bar, itr control arms, energy bushings misc. : super nice jdm seats, momo detachable steering wheel, Jdm clutster, Spoon Cf duckbill wing, vision smoked amber turn signals. COMING VERY SOON IN DAYS LS vtec ARP ROD BOLTS HEAD BOLTS AND 75 SHOT OF GIGLE JUICE look in my galler
Old 10-01-2003, 04:35 AM
Honda God
94-00 Integra had a B18B1, 1834cc, 9.2:1 c/r, 142HP@6300rpm, 127 lb/ft of torque@5200rpm (flywheel numbers)...This LS puts out about 127HP and 117 lb/ft of torque to the wheels in good shape. CAI, Header, Exhaust will boost that. The LS really moves in the much lighter Civic Chassis (2300lbs vs 2700lbs).
Well I put up the flywheel HP for the B18B1 (the engine usually called the LS), here are the flywheel numbers for the eariler "LS" motors.
90-91 Integra had a B18A1, 1834cc, 9.2:1 c/r, 130HP@6000rpm, 121 lb/ft of torque@5000rpm.
92-93 Integra had a B18A1, 1834cc, 9.2:1 c/r, 140HP@6300rpm, 121 lb/ft of torque@5200rpm.
Old 10-02-2003, 07:30 PM
You should really just go with the b18c. If you want a new motor might as well save a little more and get something you'll be way more proud of
Old 10-03-2003, 04:48 AM
Honda God
Re: Re: turbo dx or ls motor
He's right, if you don't plan on turbocharging the new motor, you plan on keeping it naturlally aspriated. The LS is a great motor to turbo, arguably the best honda motor for this, due to several factors, including the block and the tranny's longer gears. You already said you want to GSR tranny and arn't going to go with forced induction. You might be better served then going for a motor that is better suited for n/a apps, just like the LS is better suited for FI apps. The B18C1 is a great n/a motor, and it has a great tranny for n/a apps. The motor and tranny are both better suited, out of thr box, for n/a apps; just like the LS and tranny are the best suited honda motor for FI out of the box. Since you indicated you are planning to stay n/a, the B18C1 may be a better choice. For the record, I have a B18B1 (LS) in my car (I plan on a turbo eventually).
91 mr2 turbo swaping to a 3rd gen turbo motor ae86turbo MR2/MR-S 2 03-02-2011 05:46 PM
1g turbo motor into 2g none turbo car mattymat Engine, Transmission and Drivetrain 5 09-13-2005 08:48 PM
Turbo motor or supercharged motor in...? blight Celica 12 09-07-2004 01:53 PM
4G63 turbo motor with turbo for sale soyee7 Off-Topic 7 12-09-2003 07:04 PM
None turbo 88' tranny on 89' turbo motor clutch240 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 10-27-2003 08:10 PM
