Old 09-26-2003, 04:50 PM
york2600 york2600 is offline
Send a message via AIM to york2600
B18C Oil Cooler on a B20
Has anyone out there put the B18c1s oil cooler onto the B20. I have a built B20/VTEC block and I need to start moving all the acessories over onto the B20. So here's the problem. I can use the coolant pipe off the GSR and the oil cooler of the GSR, but I need a place to put the second coolant hose so that there's a complete loop. Anyone have a good spot to put this. Pictures would be great. I figure since I already have the GSR block I might as well use this handy little oil cooler.
-Tim
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Trouble with oil cooler lines marshallblazer Problem Diagnosis 2 03-11-2010 08:37 PM
Help Oil Cooler Lines oscales Tahoe 4 09-09-2009 08:44 PM
96' oil cooler lines/oil filter mount nedcharter Suburban 1 08-25-2007 09:16 PM
Oil leak in between oil cooler & the engine ngsiufung Camry/Camry Hybrid/Vista 5 03-06-2006 10:50 AM
Replacing the oil cooler lines to fix oil drips... Wick001 Blazer 21 10-27-2005 03:22 PM
