Old 09-26-2003, 08:07 AM
pmarque pmarque is offline
Sanding
What the correct steps to sand a car body before prime? just pick up the sand paper and sand directly the body or what?
thanks
pmarque
Old 09-26-2003, 08:09 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Re: Sanding
This is all in the FAQ. Have you read it yet?
Old 09-26-2003, 08:13 AM
Re: Re: Sanding
FAQ does not explain how to sand, it explains when to sand
At least I did not found it. But can you help me at all saying where to look?
thanks
pmarque
Old 09-26-2003, 08:14 AM
Ran's Avatar
Ran Ran is offline
Re: Re: Sanding
i know i havent
where is it? i might start reading it.
Ran
Please read the AF guidelines
if you haven't read them before.
Old 09-26-2003, 08:22 AM
EMAXX's Avatar
Re: Re: Re: Sanding
The FAQ is at the top of this forum. Its a post with important by it.
Here is a link
http://www.automotiveforums.com/vbulletin/t63623.html
Old 09-26-2003, 12:37 PM
hirofkd's Avatar
hirofkd hirofkd is offline
I'll give you an example, where you need and extensive sanding to prepare a body. You can omit a few steps, if the gap along the seam line isn't so big.
* Brush paint the primer along the seam line to highlight the gap.
* Eliminate the gap along the seam line with a file. Primer helps you know how much you are filing.
* Brush paint the primer again to fill the big scratches left by the file.
* Sand the area with 600-1200 (your choice) grit sand paper.
* Brush paint the primer to fill the small scratches left by the sand paper.
* Sand the area with 1200-2000 (your choice) grit sand paper.
Sand the entire body with 1200-2000 (your choice) grit sand paper to find the sink mark, and fix it if necessary. This also helps primer grab the plastic well.
Spray paint the primer evenly, and the body is ready.
Hiroaki Fukuda
Old 11-03-2003, 09:19 PM
Bryan_831's Avatar
Bryan_831 Bryan_831 is offline
Send a message via AIM to Bryan_831 Send a message via Yahoo to Bryan_831
Re: Sanding
that was great help! the brush paint primer is Gunze Sangyo Mr.Surfacer right?
Special Thanks to Desi Gangsta for the great Avatar
Current Project
Porsche 911 (996) Carrera with Putty Mods
Next Project
Nissan Skyline R34 in White, with SAS C-West Hood
"Some people look good from far.
On closer inspection, they are far from good."
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
sanding base for clear? Swansen Auto Collision Network 7 07-22-2009 11:31 AM
1st time wet sanding & uhh... did i mess up sanding or painting? chato de shamrock Car Modeling 13 03-10-2007 07:28 PM
Sanding or not sanding Svendsen Car Modeling 4 06-08-2006 11:25 AM
I need sand ladders. Matt Peckham Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 14 07-24-2001 06:30 PM
