Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 09-25-2003, 09:52 PM
iceiso iceiso is offline
Send a message via AIM to iceiso
MST research
hello, i'm doing a MST research project, and i chose to do something with cars. pretty much, i had to think up of an idea, and it doesn't have to be financially feasible and i don't have to build it.
this is my plan on making a turbocharged car with no lag...
i was thinking, could you put a small airpump with a tank after the exhaust manifold and before the turbo, and whenever the car idles, the air pump pressurizes some exhaust air into the tank. to overcome the problem is the car isn't idle (say, at a light) long enough, air can also be redirected from the BOV and into the airtank. so, whenever throttle is applied, some air rushes out of the air tank and through the turbo, so it's always (or almost always) making positive pressure.
i know this is kinda "out-there", and it would probably be a big pain in the ass and a lot of money to make work, but what are your opinions on this?hello, i'm doing a MST research project, and i chose to do something with cars. pretty much, i had to think up of an idea, and it doesn't have to be financially feasible and i don't have to build it.
i was thinking, could you put a small airpump with a tank after the exhaust manifold and before the turbo, and whenever the car idles, the air pump pressurizes some exhaust air into the tank. to overcome the problem if the car isn't idle (say, at a light) long enough, air can also be redirected from the BOV and into the airtank. so, whenever throttle is applied and the turbo isn't making positive boost, some air rushes out of the air tank and through the turbo, so it's always (or almost always) making positive boost.
i know this is kinda "out-there", and it would probably be a big pain in the ass and a lot of money to make work, but what are your opinions on whether it would work or not?
Old 09-26-2003, 06:14 PM
darkaccord darkaccord is offline
Send a message via AIM to darkaccord
I thought of that too, but then I realized the tank would have to be huge to hold enough air.
1995 Honda Accord LX...all stocked out!
http://www.cardomain.com/member_page...page_id=356187
Old 09-27-2003, 04:39 PM
Bambooseven's Avatar
Bambooseven Bambooseven is offline
and on top of that you'd have to power a compressor to actually make the charge worthwile.
MY CAR!
Old 09-27-2003, 06:57 PM
boosted331 boosted331 is offline
And on top of that 75% of the energy that actually spools the turbo comes from exhaust heat, so no, it wouldn't work.
Old 09-29-2003, 03:52 PM
haha, alright, it was worth a try. thanks for the replies though
what about injecting something like nitrous into the exhaust stream after the exhausting manifold and finding a way to combust it, and maybe have a small tank just for a little help? so, it would be pretty hot, and it would kinda mimic (sp?) what happens in an engine.
Old 09-29-2003, 04:09 PM
Re: MST research
Nitrous would be a waste of time. You could do a lil something like what anti-lag does, dump fuel right into the header which combusts and helps spool the turbo. I suppose you could also use something like propane if you wanted to.
V6 MR2 - Who's done it or researched it? revac MR2/MR-S 61 05-14-2010 06:44 PM
MST research project iceiso Engineering/ Technical 1 09-27-2003 05:06 PM
Re:)Consumer Research mika_mon CLK 0 03-14-2002 04:53 PM
After some research... HondaS2000tuner General 2 03-10-2002 03:26 AM
Danate your computer to cancer research. kris COMPLETELY off-topic 0 01-06-2002 07:29 PM
